TOS 7.0.0804 (x86) Official Release Update
Jimmsan
Sweden
Re: TOS 7.0.0804 Official Release (x86) is Released for Update
Post by Jimmsan »
TMzethar wrote: ↑01 Aug 2026, 22:37
Jimmsan wrote: ↑01 Aug 2026, 02:42 Status on my issue that I emailed on?
We recommend that you check to see if you included your forum ID and URL in the email. We need them to locate your question.
That's exactly what I did in my email.. You should find it if look properly? This what i emailed:
"Subject: TOS 7.0.0804 - Cant Mount USB Drive
Per request, here is logs and also some debug log and system report. Issue is USB Drive disc is not detected anymore so cant mount drive/storage pool
Forum link: viewtopic.php?p=59091#p59091
Forum ID: Jimmsan - memberlist.php?mode=viewprofile&u=15752"
This is unbelievable bad. It's been almost a week and not really any help. I have a traid usb drive mount disc that's it not functioning because of the upgrade right now that I need.
Jimmsan wrote: ↑02 Aug 2026, 15:21
This seems to be a specific issue that may, or may not, relate to the specific release. Maybe this would be better in a dedicated thread. Simply tacking on "I have the same problem" does not say much (and makes it much more difficult to follow.)
In the thread you mention Traid. In the posted image there is a mention of the disk being Raid0 (spanning). This implies the disk(s?) in question are mounted in a multi-disk enclosure but no mention of the type. (Different types of enclosure may behave differently, of course.)
Or, maybe you made a raid including both an attached usb and a drive in the nas itself - I'm not even sure that is recommended or possible.
The error message image posted appears to refer to a detected drive and a missing drive, so if all drives are in an enclosure is only one of the array being detected and the remaining drive(s) being miss-classified?
What type of file system was on the array? I have seen an issue reported with NTFS formatted USB drives, but Traid would not be that. Maybe this is an extension of the same issue.
vignatiev
Post by vignatiev »
I encountered issues when upgrading to firmware version 7.0.0804. After restarting the NAS, it got stuck at the BIOS screen (displaying the Terramaster logo) and wouldn't allow access to the BIOS setup utility. Removing the HDDs resolved this, after that system booted successfully.
Then I reinstalled a single 16TB HDD along with a 4TB SATA SSD for use as Hyper Cache. The SSD exhibited unusual behavior, constantly writing or reading data even when no active processes were accessing it. I attempted to remove the Hyper Cache configuration. After approximately 8 hours, I physically removed the SATA SSD. Subsequently, I received an error message indicating a corrupted storage pool. A reboot cleared the immediate error.
However, any attempt to re-create the Hyper Cache using that same HDD results in a status that cycles between "Creating" and then immediately switches to "Deleting...," regardless of which SSD drive I try to use. How can I fix this without losing data?
Other storage pool RAID1 + nvme hyper cache works good.
F4-424, F4-424__MADN0101.V08
F4-424
adam12345
Israel
Post by adam12345 »
hey After upgrading for TOS6 i am having a lot of issue with jellyfin
F2-424
at first the server would not would not start so i deleted the community app that i was using and installed via the regular store , i had alot of issues connecting it would not connecting even thought the server was up i deleted the app and the directories (/jellfin and /usr/local/jellyfin/) manually dunno if it helped but now it's working but very slow ,
i using my lg tv as a client and keeps either freezing entirely or i can scroll but it will not response to anything i click , on tos6 never had any issues
can it be permissions or old files from tos6?
nitzer71
Switzerland
Post by nitzer71 »
Update: UPS false notification issue
Just an update on my previous post.
I was receiving the notification:
"The UPS connected to device TNAS has entered AC power mode."
The UPS was not actually losing power. After checking the logs, I found that the notification appeared after a system time change/NTP synchronisation event.
The log sequence was:
Clock change detected
upsmon: Processing OS wake-up after sleep
ups_notify_on_power_restored
I noticed the latest TOS 7 release notes mention a fix related to system time consistency. I changed the NTP server to:
au.pool.ntp.org
Changing the NTP server triggered the notification once more during the initial time correction, but I have not received any further false UPS notifications since then.
The UPS itself appears to be working normally. It has not actually switched to battery mode, and there have been no power outages.
I will continue monitoring, but at this stage it looks like the issue may have been related to a system time adjustment rather than an actual UPS power event.
F4-425 Plus | 16GB RAM | Intel(R) N150 | 3× 12TB HDD (TRAID) | 1× 1TB NVMe | 1× 500GB NVMe
TMzethar wrote: ↑01 Aug 2026, 22:37 We recommend that you check to see if you included your forum ID and URL in the email. We need them to locate your question.
Unfortunately, we’ve checked several times but haven’t found your email. If you have any attachments larger than 20 MB, please include a shareable link in your email to avoid delivery failures.
If the issue isn’t related to attachments, please try sending us an email from a different account.
Silversnake
Czech Republic
Post by Silversnake »
Jellyfin ( 10.11.0)
Following issues with drive mounting (which were resolved by installing a different version of Storage Manager), I am unable to select a folder library in Jellyfin.
I have performed the following steps:
1) Uninstallation, download, and fresh installation
2) Restart
3) Running and completing the Jellyfin setup wizard
4) During the wizard setup, it is impossible to select folders other than those on the main drive. It appears that Jellyfin cannot see the other drives or their folder structures—only the main drive where the TOS system is installed (Volume1). The other three drives are in "Move" mode. The drives are visible on the network, and the Multimedia Server is working perfectly, SMB etc.
Everything worked fine in the previous version of the TOS system; this version seems to be quite problematic.
vignatiev wrote: ↑02 Aug 2026, 22:02 I encountered issues when upgrading to firmware version 7.0.0804. After restarting the NAS, it got stuck at the BIOS screen (displaying the Terramaster logo) and wouldn't allow access to the BIOS setup utility. Removing the HDDs resolved this, after that system booted successfully.
Regarding the issue you mentioned of the system “getting stuck on the BIOS screen,” Is this the first time it's happened? Please keep an eye out to see if similar issues occur in the future. Generally speaking, a reasonable amount of time is required to test and initialize the HDD.
Regarding the Hyper Cache error you mentioned, we recommend that you contact us online to schedule a remote troubleshooting session with engineers:
Please include your forum ID and the URL for this post.
adam12345 wrote: ↑03 Aug 2026, 02:27 hey After upgrading for TOS6 i am having a lot of issue with jellyfin
F2-424
What version were you using before updating to 7.0.804?
If the issue arose after upgrading to TOS 7 and was not caused by this 7.0.804 update, we recommend that you consider opening a separate thread to discuss the problem.
We’ll try to reproduce the issue based on the information you’ve provided.
After the upgrade, did you reconfigure Jellyfin to match the settings you used with TOS 6? Behavior can vary significantly depending on the settings.
We’ll keep you updated here as we make progress. Please let us know if you discover anything else.
What version of the Jellyfin Server app are you currently using?
nitzer71 wrote: ↑03 Aug 2026, 10:26
Glad that you figured out the issue, and thank you for sharing the details.
We'll discuss it to see if we can avoid UPS false alerts.
