I currently own a TerraMaster NAS running TOS 6, and I can see that TOS 7 is now available.
Could you please confirm whether an OTA upgrade from TOS 6 to TOS 7 will be made available directly through the standard TOS 6 update page / “Check for updates” section?
In other words, I would like to know if I should wait for the upgrade to appear automatically in TOS 6, or if the only supported method for upgrading from TOS 6 to TOS 7 will remain the manual update procedure.
If an OTA rollout is planned, do you have an estimated timeframe for when it will be available?
Thank you in advance for your help.
TOS 7.0.0777 Official Release (X86) is Now Available
- maincouranteforum
Re: TOS 7.0.0777 Official Release (X86) is Now Available
After update created folder
/"usr/static/images/file_manager
F4-423
maincouranteforum wrote: ↑14 Jul 2026, 15:25 Hello,
The OTA upgrade from TOS 6 to TOS 7 is being rolled out gradually by model batches. A new batch of supported models will be released approximately every two weeks.
Currently, the 425 series (including F4-425, F2-425, F4-425 Plus, and F2-425 Plus) running TOS 6.0.794 has started receiving the TOS 7 OTA update.
The 424 series (including F4-424, F2-424, F6-424, F4-424 Pro, F4-424 Max, and F6-424 Max) is planned for the next rollout.
Other supported models will be added gradually according to the release schedule. Please make sure your NAS is running the required TOS version before checking for updates.
For the supported models, required versions, and detailed upgrade information, please refer to the official announcement:
TOS 7 Is Now Out of Beta — Official Release
Yes, an update for Portainer is planned and is currently in the upgrade schedule. It will be updated in a future TOS release.
Hi. We can see that you've disabled it for now, but we're not sure if it will turn back on after a reboot. When you restart your NAS next time, please keep an eye on whether the service stays off.jayjay wrote: ↑11 Jul 2026, 18:59 there are actually a lot of processes there, but I found that the drives go to sleep when I turn off smartI know it's not a great solution, but nothing else helpedCode: Select all
systemctl stop smartmontools.service
Additionally, in the smartmontools logs I noticed that the process queries the disks for temperature every 30 minutes, maybe this is the reason for waking up?
If it comes back on even on the new version, we'll need further investigation.
