[ Syncthing ] Continuous Replication/Cluster Sync
samius
Re: [ Syncthing ] Continuous Replication/Cluster Sync
Post by samius »
On last beta 7.0.364 dosnt start :(
Error: ERR Failed to ensure directory exists (error="mkdir /usr/local/@APP_CONFIG/SyncThing: permission denied" log.pkg=main)
Although it launched in the first 7 beta.
F4-424 MAX TOS 7
3rd party apps released for previous OS version are not fully compatible with TOS7. Some of them even does not start. You need to wait for a tpk that contains TOS7 in the filename
samius
Post by samius »
I know, but maybe you can tell how to edit the launch script so that it works?
F4-424 MAX TOS 7
samius
Post by samius »
Temporarily changed the user in the startup script
F4-424 MAX TOS 7
TOS7 version will be released soon
OneMany
Post by OneMany »
samius wrote: ↑11 Jan 2026, 18:20 Temporarily changed the user in the startup script
Подскажи, пожалуйста, где именно изменил? У меня TOS6 , но ничего не запускается. :?
samius
Post by samius »
OneMany wrote: ↑20 Feb 2026, 04:50
your app drive/@apps/SyncThing/init.d/service
USER=your user
GROUP=your group
But, on TOS6 it no need.
F4-424 MAX TOS 7
OneMany
Post by OneMany »
samius wrote: ↑21 Feb 2026, 03:01
Всё верно. Я просто забыл открыть порты на своём компе. Сейчас заработало.
Спасибо за подсказку. ))
tnasuser99
Post by tnasuser99 »
the TOS4 download link leads to a missing file error - would it be possible to get that back up? my old NAS has lost syncthing and now i cannot reinstall it.
I'll have to check if I still have it, but it's a very old version and I can't guarantee that it works.
