TOS 7.0.0612 Beta (X86) is Released for Update
Nitrokalel
Mexico
Re: TOS 7.0.0612 Beta (X86) is Released for Update
Post by Nitrokalel »
EthanLiu wrote: ↑28 Jul 2026, 18:47
Nitrokalel wrote: ↑03 Jun 2026, 01:47
Thank you for your feedback! Regarding the virtual machine import issue, we have optimized the process in the latest version. The system can now import OVA files based on their actual file size. We recommend upgrading the application to version v1.0.055 or later. After the upgrade, the issue should be resolved and you can use the feature normally. If you have any further questions, please feel free to contact us anytime.
en efecto, esta es la funcion que se necesita, muchas gracias, con esto los usuarios estaran mas seguros, la aplicacuin aun puede mejorar pero ya son detalles. con esto completan las funciones BASICAS de un hypervisor confiable, ya solo falta algun mecanismo de respaldo de la maquina virtual, ojo que no sea exportar o importar,,, pudieran agregarlo a su herramienta de centralized backup
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod)
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod)
F2-423 (2x18TB, TRaid, 32GB, prod)
F2-221 (6TB+10TB, TRaid, 10GB, prod)
D1 SSD (2TB, prod)
Nitrokalel wrote: ↑30 Jul 2026, 01:35
EthanLiu wrote: ↑28 Jul 2026, 18:47 en efecto, esta es la funcion que se necesita, muchas gracias, con esto los usuarios estaran mas seguros, la aplicacuin aun puede mejorar pero ya son detalles. con esto completan las funciones BASICAS de un hypervisor confiable, ya solo falta algun mecanismo de respaldo de la maquina virtual, ojo que no sea exportar o importar,,, pudieran agregarlo a su herramienta de centralized backup
We'll discuss your idea of using Centralized Backup to back up VMs.
The request has been accepted and is currently being processed.
Nitrokalel
Mexico
TMzethar wrote: ↑22 Oct 2026, 12:17
gracias
D1 SSD (2TB, prod)
