TOS 6.0.783 (X86) is Released for Update
mmick
Portugal
Re: TOS 6.0.783 (X86) is Released for Update
Post by mmick »
CursaYang wrote: 14 Oct 2025, 11:05
luismartin wrote: 14 Oct 2025, 06:41 This isn't just a question for 6.0.783, it applies to all other updates.
I have TOS installed on only one M.2 drive, but not on any of the 12 drives in my T12-450.
Would I have less risk of RAID data loss by disconnecting all 12 drives, updating the M.2 drive, shutting down, and reconnecting the drives again?
Version 6.0.783 has added a system disk management feature. You can update the system separately on the M.2 drive and then insert other HDDs.
One question I have the F4 423 and I have four hard disks. If I install now a M2 drive, can I install the operating system on it, and the nas will boot from it?
luismartin
Post by luismartin »
As far as I know, you need to perform a Factory Default, and when it shows you where to install TOS, choose M.2 so that it boots only from M.2.
I recommend performing a Backup Sustem Configuration first.
Lex
Post by Lex »
mmick wrote: 16 Oct 2025, 20:59
NVMe is system
F4-423
In version 6.0.783, if you want the NAS to boot from the newly installed M.2 drive. After installing the M.2 drive, you can directly migrate the system from the HDD to the M.2 drive.
mmalchuk
Post by mmalchuk »
F5-221 was updated from 6.0.770 to 6.0.783-01200 without any issues.
F4-423 was updated from 6.0.750 to 6.0.770 with issue of no UI, booting from system disk in BIOS helps, then updated to 6.0.783-01200 without any issues.
F5-221 | 7.0.0517 | 10GB RAM | 4x4.00TB Seagate IronWolf TRAID/BTRFS
F4-423 | 6.0.794-01324 | 32GB RAM | 2x512GB NVME System | 4x8.00TB Seagate IronWolf TRAID/BTRFS
mmalchuk
Post by mmalchuk »
mmalchuk wrote: 18 Oct 2025, 19:08 F4-423 was updated from 6.0.750 to 6.0.770 with issue of no UI, booting from system disk in BIOS helps, then updated to 6.0.783-01200 without any issues.
Update: The multimedia server is disabled after the update. I don't know if the 770 or the 783 updates disabled it. ReEnable worked.
mmick
Portugal
Post by mmick »
CursaYang wrote: 17 Oct 2025, 17:41 In version 6.0.783, if you want the NAS to boot from the newly installed M.2 drive. After installing the M.2 drive, you can directly migrate the system from the HDD to the M.2 drive.
Great news, thank you! Do you know if there is any special minimum size for the M.2 SSD? (ATM I have a spare 256 GB NVMe M.2 SSD)
SSD has no capacity requirements; 256GB is also acceptable.
To put that in perspective, The operating system partitions occupy about 11Gigabytes (with overhead).
I run a pair of 500GB nvme in Raid (1). This gives me a Storage pool space of >450GB.
How much space you might actually need would depend on the intended use for that space.
Lau6311
Malaysia
Post by Lau6311 »
tronesmethod wrote: 12 Oct 2025, 15:11
Noted your happiness. 8-)
Appreciate advice from you and anyone : Can I jump straight to TOS 6.0.783 from current 648 ?
Reason is to avoid the issues caused by intermediate TOS versions. Thank you.
I currently have same F2-223 with TOS 6.0.648 months ago with minimum issues. As a simple user, Emby for media, browser for intensive files transfer, Photo for handphones media management. 5 UPS for emergency power management for PCs, routers and 2xNAS.
Comment: I like the new feature of selectively residing TOS at all drives like HDD and SSD, as preferring using faster SSD for TOS. Noted that when upgrading from TOS 5 to 6, all drives (2 HHD and 2 NVME SSD) have TOS 6 installed, but after changing the cache SSD to balance mode, I lost the TOS at cache SSD, only 3 drives have TOS instead of all 4, and I do not know the priority accessing TOS is from HDD or SSD ??
So far, I am happy with F2-223 as a good entry level NAS, fast enough for normal functions (using NAS 2x2.5Gbe and PC 2x2.5Gbe with one using ethernet adapter thru a 1Gbe switch with max speed about 220-250 GBps using SMB multichannel.
Will report status after a successful TOS upgrade.
F2-223, TOS 6.0.648, 2x8T N300 HDD Vol 1 & 3 (Singles)
1x1T Kingston NVME SSD Vol 2 (Single)
1x256G Hynix NVME SSD Hyper Cache (Balance Mode, 238G)
32G RAM
