TOS 6.0.535 (X86) is Released for Update
Tom
Ireland
Re: TOS 6.0.535 (X86) is Released for Update
Post by Tom »
UPS issue is still there I have a F5-221 and after a period of time the Enable UPS support box unticks its self and shows UPS is not connected.
If I reboot it will work for a period of time but will stop detecting the UPS and uncheck the Enable UPS support box,
UPS is powerwalker and is on the approved list of UPS UPS works without issue if I connect it to Linux server running NUT.
When the UPS is detected it populates the information in UPS information and I can enable UPS support and set the TNAS as the network UPS server
after a period it stops working and doesn't detect the UPS and I can't enable UPS support unless I reboot the TNAS
This is the same problem other users have reported using different makes and models of UPS's that are also on the approved list. I suspect that the issue is TNAS software-related can you get a fix included in the next TOS 6 release.
zonatar wrote: 17 Nov 2024, 16:46 In tos6 I can't keep the read and write privileges for the various users in the newly created subfolders in "public", even if I checked the option to make them free to all the subfolders every time BitTorrent creates a new folder I have to go and change the privileges every time.
Quite boring.
We have not observed any similar situation when downloading apps from the App Center. Can you tell us how you install and use BitTorrent?
Rafaelrdguez
Spain
Post by Rafaelrdguez »
Hola
Tengo un T2-423 con Tos 6.0.535 y el ventilador sigue sin funcionar en modo automático....en modo manual sin problema.
Aunque no es muy importante espero que se arregle en futuras actualizaciones.
Gracias
zonatar
Italy
Post by zonatar »
TMzethar wrote: 19 Nov 2024, 14:06
Quite boring.
From the main store, in tos5 all was fine.
zonatar
Italy
Post by zonatar »
Quite boring.
5. Fixed the issue that some shared folders could not inherit permissions.
I have this problem, it's from the 6.0.507 update, i install first the 6.0.500 and then the system auto update my nas on the 6.0.535, any suggestion how i can fix the problem?
zonatar
Italy
Post by zonatar »
No sorry, i forget, i update my nas from versions 5.1.145 to 6.0.530 and then i reset the system to install the so on a specific ssd, in this case the system was 6.0.500 and then the autoupdate was on the 6.0.535.
Maybe i must reset again the system, update it on 6.0.507 and then on .535?
zonatar wrote: 20 Nov 2024, 02:45
Regarding permission inheritance, if the box in the attribute of a subfolder is empty, it means that the permissions are inherited from the previous directory. Next to the box, there is a column called “Permissions”, so it's easy to take this into account. If you check them, they will have their own independent permissions.
Rafaelrdguez wrote: 19 Nov 2024, 23:52 Hola
Gracias
No fan-related errors have been detected yet, and there have been no other reports of TOS 6.0.535 fan failures. Therefore, we are unable to implement the fix you are expecting.
What is your NAS model number? Can you please describe the problem?
TMzethar wrote: 20 Nov 2024, 18:34
Have to comment that this version is the first with which I have felt (reasonably) confident about the auto fan operation :o :shock: :mrgreen:
I can observe the fan being on 0rpm after boot, and then, after running a few things, see the fan kick in. Only running nvme at the moment. Hopefully adding running hot hdd won't change that. ;)
zonatar
Italy
Post by zonatar »
TMzethar wrote: 20 Nov 2024, 18:30
It doesn't work for me, i mean the box was empty but the permissions was not, doesn't get the inheritance permission.
After i manually change it it work for me.
