TOS 5.0.158 (x.86) is Released for Update
Rick
Netherlands
Re: TOS 5.0.158 (x.86) is Released for Update
Post by Rick »
I see that version 163 is already online, this is a latest version.
YuckFou
Post by YuckFou »
After updating from 5.0.160 to 5.0.163, now clicking on the bell on the homepage to see past notifications does nothing. A problem only on my side?
YuckFou
Post by YuckFou »
Never mind. I just noticed I didn't have any new notifications so the notifications icon wasn't displayed and force of habit of clicking the first icon following the system information got me.
MisterXY
Germany
Post by MisterXY »
YuckFou wrote:
yes and i miss the usb icon to disconnect the usb drive in this line.
kenfrog
Post by kenfrog »
noticed that the reboot and verification process takes much longer on .163 than it has prior to this version. I have not checked dmesg or logs but the system seems to take 10-20 mins to fully boot and rejig the OS.
Suspect that daemon changes (KDBUS OR KMS) and services are checking their configs. Plex is also known to chmod or chown to its home (whole Metadata lib) - still need to look into why, ssh is blocked until the system fully loads so I have to wait.
kenfrog
Post by kenfrog »
I was incorrect here - the DMEGS shows recovery done on the array swap across each disk and e2fsck to check the host filesystem
[ 47.089788] ***ERROR***: SCST device for SCSI device 7:0:0:0 not found
[ 57.009496] md: md8 stopped.
[ 57.028757] md/raid1:md8: active with 1 out of 72 mirrors
[ 57.028794] md8: detected capacity change from 0 to 1023868928
[ 57.038500] md: recovery of RAID array md8
[ 57.040055] md: md8: recovery interrupted.
[ 57.056992] md: recovery of RAID array md8
[ 57.058627] md: md8: recovery interrupted.
[ 57.082176] md: recovery of RAID array md8
[ 57.083786] md: md8: recovery interrupted.
[ 57.106975] md: recovery of RAID array md8
[ 57.248477] Adding 999868k swap on /dev/md8. Priority:-2 extents:1 across:999868k
[ 57.279869] md: md0 stopped.
[ 57.283893] md/raid:md0: device sda4 operational as raid disk 0
[ 57.283903] md/raid:md0: device sde4 operational as raid disk 4
[ 57.283906] md/raid:md0: device sdd4 operational as raid disk 3
[ 57.283908] md/raid:md0: device sdc4 operational as raid disk 2
[ 57.283911] md/raid:md0: device sdb4 operational as raid disk 1
[ 57.284609] md/raid:md0: raid level 5 active with 5 out of 5 devices, algorithm 2
[ 57.302314] md0: detected capacity change from 0 to 71986803900416
[ 65.745870] md: md8: recovery done.
[ 1069.819397] flashcache: flashcache-3.1.1 initialized
[ 1073.426889] EXT4-fs (dm-0): warning: mounting unchecked fs, running e2fsck is recommended
[ 1073.909103] EXT4-fs (dm-0): mounted filesystem without journal. Opts: user_xattr,acl,usrjquota=quota.user,grpjquota=quota.group,jqfmt=vfsv1
[ 2429.228954] udevd[6161]: specified group 'lp' unknown
[ 2429.229094] udevd[6161]: specified group 'disk' unknown
[ 2429.233919] udevd[6165]: starting eudev-3.2.4
[ 2429.245836] udevd[6165]: specified group 'lp' unknown
[ 2429.245933] udevd[6165]: specified group 'disk' unknown
[CockMaster@TNAS-F5-422 root]# [ 10.023873] md: recovery of RAID array md9
{L_BUTTON_AT}kenfrog
Your storage pool seems not mounted successfully. May I know why there is a verification during the system update? did you reinstall the system?
Hobba
Post by Hobba »
left the management window open for a while and came back to he clock saying it was 31:50:51 AM
May I know what is the "management windows" ? would you show a photo?
YuckFou
Post by YuckFou »
MisterXY wrote:
Refreshing the page solves it for me
