TOS 5 Beta is released for testing NOW!
krisprolls
Re: TOS 5 Beta is released for testing NOW!
Post by krisprolls »
good evening,
after installing TOS 5, the login works for a few hours then impossible to log to my account.
I have to full install again.
Any clue ?
regards
Tricky
Post by Tricky »
I have just updated the TOS5 application and now can't log in, says password is incorrect, and It's still trying to add the extended password, is that the problem?
Anyway, try to reset password and input the normal username but cannot proceed, shame until now TOS5 was working fine.
krisprolls
krisprolls wrote:
> good evening,
> log to my account.
> Any clue ?
> regards
I should add that I can access my NAS through SMB and AFP, but not through http.
thanks
dissidence
Post by dissidence »
{L_BUTTON_AT}dissidence
I have tried that and from what I can see all the IP addresses are correct. if I click on the see beta box I can then see app, but all fail to even download.
everything was great until this last update, I have even tried doing a factory reset now to no avail.
TMSupport wrote:
> Your device may not be connected to the internet, please follow the steps
> to solve the issue.
> 1. Enter the Control Panel-Network Settings-Network Interface, edit the
> used network port, and modify the DNS to 8.8.8.8
> 2. Confirm whether the gateway is consistent with the computer, if it is
> different, you need to change it to be consistent with the computer
> 3. Check the "Set as Default Gateway" button, and then click
> "Apply".
{L_BUTTON_AT}krisprolls
Is there any error tips on the login page?
dissidence wrote: ↑02 Apr 2022, 08:51 I have tried that and from what I can see all the IP addresses are correct. if I click on the see beta box I can then see app, but all fail to even download.
Is there any error tips when you download the apps?
krisprolls
just a red message incorrect name/password really weird as I can access my NAS through smb/afp with the same name and password.
Tricky
Post by Tricky »
By the sounds of it doing a reset and reinstalling TOS5 may well end up with the same problem, maybe time to go back to the std TOS version.
krisprolls wrote: ↑02 Apr 2022, 16:00
TOS 5 adopts the pam authentication mechanism. When you enter the wrong password on the login page for more than three times, even if you enter the correct username and password, you cannot log in successfully. You need to wait two minutes before logging in with the correct username and password.
krisprolls
TMSupport wrote:
> [quote=krisprolls post_id=17731 time=1648886451 user_id=4942]
> [/quote]
I never entered a wrong password or user name.
I tell you there is a bug somewhere.
anyway hope it will be fixed soon.
Thank for the great job you did for the 5th version.
