[ Jellyfin ] The Free Software Media System
lucius
Re: [ Jellyfin ][ 10.8.1.0 ] The Free Software Media System
Post by lucius »
after installed TOS 5 version tpk, I got error screen as attachements, can anyone help me?
I will check this evening
You can try to access jellyfin directly with http://nasip:8096
I cant't reproduce your issues, tried a fresh install and i can access the frontUI.
Can you answer below ?
  • your TOS language
  • How many Volume's you have on your NAS
  • On which Volume have you installed the apps
  • Was a fresh install of TOS5 or an upgrade from TOS4 to TOS5
lucius
Post by lucius »
Hi outkastm:
reply to you as follows:
Your TOS language => It's Chinese, althrough I change to English, I got same error screen.
How many Volume's you have on your NAS => 1.81TB/5.45TB
On which Volume have you installed the apps => Actually I have only 1 volume, my NAS model is F2-221.
Was a fresh install of TOS5 or an upgrade from TOS4 to TOS5 => It's a fresh install of TOS5.
One more question, which user did the app installation? The superuser created during TOS installation or a user created later from TOS interface?
I will try to reproduce the issue
lucius
Post by lucius »
outkastm wrote: 14 Jul 2022, 01:31 One more question, which user did the app installation? The superuser created during TOS installation or a user created later from TOS interface?
Hi Sir:
it's superuser, I'm admin and i don't create any other user in system.
MisterXY
Germany
Post by MisterXY »
Small question, does the error only appear after a reboot or directly after the installation?
Jellyfin didn't work for me after a reboot either.
I tried to start it manually (no jellyfin autostart) and it just wouldn't start.
{L_BUTTON_AT}MisterXY
The issue that the app doesn't start after reboot is fixed
Download again the app and install it
MisterXY
Germany
Post by MisterXY »
After a reboot, i can't start it. If i hit the start module button, it did not start.
Have you downloaded again the app and install it? Because I made some changes after your first message
