[ Syncthing ] Continuous Replication/Cluster Sync
scout71
Italy
Re: [ Syncthing ] Continuous Replication/Cluster Sync
Post by scout71 »
Hi, sorry for the inconvenience. Do you plan to also update this app for the new TOS 6?
Yes it will be done.
is done
shawnhendriks
Post by shawnhendriks »
Hello. I've just installed Syncthing for the first time on a new NAS with TOS 6. Has the user permission system changed? I need to use folders that are not in the syncthing folder. I have tried the process covered earlier in this thread of creating a syncthingapp group and giving it access to the folders I want and then restarting syncthing. I still get permission errors in syncthing. I also tried assigning allusers with read write permission for those folders and still get the error. If I use folders located in the syncthing folder everything works fine but that's not an option for me.
Edit: never mind, a second re-install of syncthing seemed to give things a kick go the syncthing user working with my folders.
scout71
Italy
Post by scout71 »
Good morning, after the last update of TOS6 the app stopped working. It tells me permission denied for each folder. Before everything worked perfectly (always with TOS6).
Do you know what could have happened? I didn't change anything, just updated.
samius
Post by samius »
a new version has appeared on the official website. for the working, need to update startup script
F4-424 MAX TOS 7
Will be updated
v2.0.7.0 is out
YCK
Post by YCK »
Hi, I want to install Syncthing on my F4-210, but I can't install it. Is it because Syncthing doesn't support the F4-210? Or am I not finding the correct installation method?
Thanks for your help!
brucewayne8596
Honduras
Post by brucewayne8596 »
Hi I am getting this error message on my F4-210 can I get some assistance in setting this up? Got this device a couple of months ago on an amazon sale and was not aware this was already eol. Would love to get this service working.
I get this error message when I try to install the tpk file.
