TOS 7.0.0777 Official Release (X86) is Now Available
Re: TOS 7.0.0777 Official Release (X86) is Now Available
quella wrote: 11 Jul 2026, 02:35
If you can only see a subset of apps in the APP CENTER, this issue is usually related to your network. If you have confirmed that your NAS’s network connection is working properly — for example, you can download apps or enable TNAS Online — please visit the link below to schedule a remote troubleshooting session with our online customer support:
Bartman wrote: 10 Jul 2026, 22:59 Installed OK, but Hypercache does not seem to stop deleting, been going on for over 24 hours, I even manually upgraded to this version but is still shows the same. Also theOpenclaw will not install, fails all the time, dread to see what else stops.
May I ask which version your TNAS was running before updating to this version? Also, please check the system dashboard to see if the system is sluggish.
jayjay
Niger
Post by jayjay »
TMroy wrote: 09 Jul 2026, 13:02
there are actually a lot of processes there, but I found that the drives go to sleep when I turn off smart
systemctl stop smartmontools.service
I know it's not a great solution, but nothing else helped
Additionally, in the smartmontools logs I noticed that the process queries the disks for temperature every 30 minutes, maybe this is the reason for waking up?
quella
Post by quella »
CursaYang wrote: 11 Jul 2026, 08:10
Thanks so much for the feedback. Yes, I can confirm that Terramaster is using a non-standard ssl port (82) for the App Center. Once I allowed SSL to use the specific port on the firewall, all the apps and app updates showed up without an issue in the App Center. Thanks for the recommendation. I would have liked to have seen the App Center use the standard SSL ports over using a different non-standard one, but I understand.
nikk
Post by nikk »
My Hyper Cache has been stuck in the "Deleting" state for over 24 hours while in Balanced mode. Restarting the NAS has not resolved the issue. Could you please advise on how I can safely force-remove the cache?
crisisacting
Post by crisisacting »
nikk wrote: 11 Jul 2026, 23:02
All active file services need to be disabled for that process to successfully complete the hyper-cache deletion.
A reboot, as you experienced, doesn't fulfill that requirement.
nikk
Post by nikk »
crisisacting wrote: 12 Jul 2026, 00:48
All file services need to be disabled for that process to successfully complete the hyper-cache deletion.
Thanks for the clarification! That makes sense now. However, I do think this process could be made more transparent to users—nowhere in the interface does it indicate that all services must be disabled beforehand. Even with this new understanding, I'm running into an issue: not all services appear to have a stop/disable button. Could you guide me on how to stop those services, or is there a workaround?
OttO1916
Netherlands
Post by OttO1916 »
Both my F5-221 and F2-221 upgraded to v7.0.0777 without any issues. Thanks!
F5-221 - TOS7.0.1140 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1140 - 2x3TB JBOD - 1x4TB Single USB
nikk wrote: 12 Jul 2026, 03:09
It is not necessary to terminate all services; only those that have active handles on the volume directory need to be stopped. Please refer to the following instructions for identifying and stopping services that are currently using the volume:
viewtopic.php?t=5955
jayjay wrote: 11 Jul 2026, 18:59
We will conduct a verification of the matter you have brought to our attention.
