TOS 7.0.0765 Official Release (X86) is Now Available
OlRedRooster
Re: TOS 7.0.0765 Official Release (X86) is Now Available
Post by OlRedRooster »
Metrogeek wrote: 01 Jul 2026, 14:40 F4-425 Plus here. Updated to latest version this morning without any problems. I also updated some of my Terramaster community place apps with their tos 7 versions.
Just noticed i can't open any of those apps in the app center. When i click open, i get a 502 bad gateway. All of the apps are working and accessible by the nas IP adress and ports.
I tried to reboot the NAS, clearing browser cache and cookies, tried also incognito mode and other browsers.
Also tried to re-install the apps and still same problem.
Now i can't access tailscale console management. Only the apps from community place, all other apps i can open them.
Anyone else?
Thank you
Did you get this fixed eventually?
I'm having the same problem with Jellyfin installed from the app store and Caddy installed from community apps. Caddy is still running fine, and jellyfin can be hit using a different port than the shortcut uses, but I'd like those shortcuts to both work without having to reinstall the app(mainly Jellyfin, I don't want to risk losing anything by reinstalling).
digi999
Post by digi999 »
OlRedRooster wrote: 04 Jul 2026, 23:33
Anyone else?
Thank you
watching as I get exactly the same if I click my installed apps from the TOS7 front screen
Metrogeek
Post by Metrogeek »
Anyone else?
Thank you
Yes i fix the issue by installing PHP 7.4 from the app center as TM support reply
marethari
Belgium
Post by marethari »
Updated my Terramaster F4-223 to 7.0.0765 (went from 5->6->7.0747 -> this one). Now I have an issue assigning permissions for an user group for a specific folder. If I'm assigning them from the shared folders, it works, but as soon as I go to the file manager and try to check the permissions from there, the permission for the user group disappears even if I don't do any changes or press apply. If I try to apply the permissions from the file manager, they are not saved. Is this a bug with the new version or is this the expected behavior?
marethari wrote: 05 Jul 2026, 01:23 Updated my Terramaster F4-223 to 7.0.0765 (went from 5->6->7.0747 -> this one). Now I have an issue assigning permissions for an user group for a specific folder. If I'm assigning them from the shared folders, it works, but as soon as I go to the file manager and try to check the permissions from there, the permission for the user group disappears even if I don't do any changes or press apply. If I try to apply the permissions from the file manager, they are not saved. Is this a bug with the new version or is this the expected behavior?
Thanks for reaching out, and apologies for the inconvenience.
We've noted the issue you described and are now investigating it. We'll keep you updated on our progress.
You may also consider booking an online appointment with an engineer for remote assistance if needed.
OttO1916
Netherlands
Post by OttO1916 »
My F2-221 and F5-221 upgraded to 7.0.0765 without issues
Thanks!
F5-221 - TOS7.0.1140 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1140 - 2x3TB JBOD - 1x4TB Single USB
apvm
Post by apvm »
F4-424 upgraded to 0765 but not test yet, funny thing is I just upgraed from TOS 6 to TOS 7 0747 version and it said a new update for TOS 7 after upgraded sucessfully to 0747. So no time to test either 0747 or now 0765.
nikk
Post by nikk »
[BUG] Apps don't auto-start after reboot – App Center status out of sync
Problem:
After every system reboot, applications installed from the App Center (Docker Engine, Docker Manager, Emby) show as "Not Enabled" and do not start automatically. I have to manually activate them each time.
What I've tried:
I created a trigger-based scheduled task to start Emby using:
/etc/init.d/emby start
The service starts successfully after reboot, but the App Center still shows the app as "Not Enabled". The status doesn't update to reflect that the service is actually running.
Core issues:
No built-in "Auto-start on boot" option for installed apps.
Task Scheduler lacks a "Run at system startup" trigger for services – only hourly or event-based schedules.
App Center status does not sync with the actual service state when started manually/scripted.
Expected behavior:
Apps should auto-start after reboot (or at least have a toggle for it).
Task Scheduler should include a startup trigger option.
App Center should correctly display the real status of each application.
Device: F2-425 Plus
TOS Version: 7.0.0765
Affected Apps in my case: Docker Engine, Docker Manager, Emby
Phil
Post by Phil »
nikk wrote: 06 Jul 2026, 01:02 [BUG] Apps don't auto-start after reboot – App Center status out of sync
Problem:
What I've tried:
Core issues:
Expected behavior:
Device: F2-425 Plus
Thank you for your detailed description. We have identified and resolved the issue you reported, and we expect to address it in the next version. I will notify you again after the version is released.
