If I upgrade from 6.0.794 to 7 with VirtualBox installed on 6, will VirtualBox still work on 7. Can I then install Virtual Machine application while I still have VirtualBox installed.
I use USB Passthrough on VirtualBox with a VM with Home Assistant, so I need Home Assistant to continue to work with the USB dongle for Zigbee/Zwave home automation devices.
I see TOS 7 is launching on June 23rd in 7 days, so I would like to upgrade, but need to know that VirtualBox will still work.
Thanks,
TOS 7.0.0706 Beta (X86) is Released for Update
Re: TOS 7.0.0706 Beta (X86) is Released for Update
Hardware: F6-424 Max, 24GB RAM, 2 x 500GB SD Ultra 3D RAID1, 3 x 12TB WD Red Plus TRAID, 2 x NVMe 2TB Quick Cache, 1 x 18TB WD USB3 Backup
Operating System: TOS 7.0.0746
Applications: Plex, VMs or VirtualBox, Docker, USB Copy
Really? Where did you see that?
You can find the information from TM official site https://www.terra-master.com/
We have not received any reports of similar issues so far. Please confirm whether the network connection is normal, whether the system has been successfully updated, and whether SMB and SFTP have started properly. If everything is fine, please enable debug mode, restart your TNAS device, observe it for a few hours, and then send us the debug log for analysis. Thank you!
I'm confirming the same error in the latest TOS 7 beta with MariaDB and phpMyAdmin.storageninja wrote: ↑13 Jun 2026, 21:43 I did re-install MariaDB+phpMyadmin+MyWebSQL but all ends in:
502 Bad Gateway
nginx/1.18.0 (Ubuntu)
Could we debug this? It seems that its not working fine on an F4-SSD, has to do with the warning in the release notes about the root filesystem?
It worked perfectly before applying the latest beta.
PHP Version: 7.4
http://192.168.1.190:8181/phpMyAdmin/
https://tf8.local:5443/phpMyAdmin/
https://192.168.1.190:5443/phpMyAdmin/
502 Bad Gateway
Same error in adminer
http://192.168.1.190:8181/mysql/adminer/
TM F8 SSD: 16GB RAM. 6TB TRAID EXT4:
TOS 6.0.610: Plex Server 1.41.1.9057: qBitTorrent 4.1.13: Bot.Torrent 4.0:
TM F8 SSD Plus: 32GB RAM. 4TB RAID0 EXT4:
TOS 6.0.531: MariaDB 10.3.29: phpMyAdmin 5.1.22:
[ DekkaR ]
[ DekkaR ]
storageninja
Solution is to install php 7.4 and not 8.0DekkaR wrote: ↑17 Jun 2026, 17:20I'm confirming the same error in the latest TOS 7 beta with MariaDB and phpMyAdmin.storageninja wrote: ↑13 Jun 2026, 21:43 I did re-install MariaDB+phpMyadmin+MyWebSQL but all ends in:
502 Bad Gateway
502 Bad Gateway
But isn't that just the announcement of the public beta? I obviously know about that as I'm here. I can't see any mention of a 23rd June release there.MikeZhang wrote: ↑17 Jun 2026, 16:05You can find the information from TM official site https://www.terra-master.com/
- sianderson
- Silver Member
while looking through the website this one made me chuckle, whats a "Filee Manage"?MikeZhang wrote: ↑17 Jun 2026, 16:05You can find the information from TM official site https://www.terra-master.com/
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Yes it is still supported in TOS7, you may upgrade after we release final TOS7
With the release of TOS 7 just around the corner, will there be another beta release or was 706 the last "scheduled" one?
F4-424 Pro also at 7.0.0777
D4-320
D4-320
