TOS 7.0.0706 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0601 or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first.
Important: This update is only applicable to TOS 7.0.0601 and newer. Users with older versions must first upgrade to 7.0.0601 before applying this update.
Warning:
1. It has been identified that certain models of the 21/22 series (F4-221, F4-421, F5-221, F5-421, F5-422) may experience disk recognition issues with slots HDD3-HDD5 after updating. This issue is still under investigation. Users with the above models are advised NOT to update and continue using TOS 7.0.0601.
2. After a system update, files maintained by the system in the root file system will be aligned with the TOS 7 installation package, and some built-in files and tools will be removed. Therefore, if an application fails to open after the update, please go to the App Center to install the PHP 7.4 dependency required by the application. Affected software includes: Web Server, VirtualBox, FreshRSS, Joomla!, MantisBT, MyBB, Net2FTP, MyWebSQL, Nextcloud, e107_cms, elFinder, IBOS, MariaDB, phpBB, phpMyAdmin and WordPress
Here, we sincerely thank @weerasak, @rfbjr, @Nitrokalel, @snapsh0t, @Tom, @crisisacting, @Kanuki, @yxyx999, @Gremlin, @OttO1916, @joka388, @oscar1412, @usersky, and others for your sharing and feedback. Your support helped us quickly identify and fix multiple issues.
Update Notes
Bug Fixes:
1. Fixed an issue where uploading files in Safari browser might fail.
2. Fixed an issue where the scale values in the resource monitor did not match the actual values accurately.
3. Fixed an issue where the logrotate configuration item was duplicated.
4. Fixed an issue where the help document link in File Manager was broken.
5. Fixed an issue where passwords for some functions were stored in plain text in configuration files.
6. Fixed an issue where the socket proxy did not take effect when the proxy was enabled.
7. Fixed an issue where the disk health status on some pages was inconsistent with the description on the disk page.
8. Fixed an issue where the hover tooltip for some buttons disappeared.
9. Fixed other known issues.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.540 for Windows OS.
- MD5: AFB7CD77DE2A4F0434D69D52D15959AF
2. Download TNAS PC 5.2.540 for macOS (x86 architecture).
- MD5: 715FEB00FDB06DF4CC9A228622566F70
3. Download TNAS PC 5.2.540 for macOS (ARM architecture).
- MD5: A6954F192DD23AF7374CF2AF20190B6C
4. Download TNAS PC 5.2.540 for Linux.
- MD5: A5B13A2C2C9B0F9FFFCBDF6F3BA9E342
5. Download TNAS Mobile 3.5.068 for Android.
6. TNAS Mobile for iOS: https://testflight.apple.com/join/wFWYABJS
Lex
Re: TOS 7.0.0706 Beta (X86) is Released for Update
Post by Lex »
Update is ok
F4-423
rfbjr
Post by rfbjr »
All three devices updated without issues
F4-424 Pro also at 7.0.0777
D4-320
crisisacting
Post by crisisacting »
Test bed TNASes updated successfully.
rfbjr
Post by rfbjr »
Logrotate: There is still issues, none of the conf files expect the log file to be there already. Is it affecting normal operational, probably not, but still.
Jun 10 08:00:08 LittleDude systemd[1]: Starting Rotate log files...
Jun 10 08:00:08 LittleDude logrotate[21951]: error: nginx:1 duplicate log entry for /var/log/nginx/access.log
Jun 10 08:00:08 LittleDude logrotate[21951]: error: found error in file nginx, skipping
Jun 10 08:00:08 LittleDude logrotate[21951]: error: rsync:1 duplicate log entry for /var/log/rsyncd.log
Jun 10 08:00:08 LittleDude logrotate[21951]: error: found error in file rsync, skipping
Jun 10 08:00:08 LittleDude logrotate[21951]: error: samba:1 duplicate log entry for /var/log/samba/log.smbd
Jun 10 08:00:08 LittleDude logrotate[21951]: error: samba:13 duplicate log entry for /var/log/samba/log.nmbd
Jun 10 08:00:08 LittleDude logrotate[21951]: error: found error in file samba, skipping
Jun 10 08:00:08 LittleDude logrotate[21951]: error: sssd-common:1 duplicate log entry for /var/log/sssd/sssd.log
Jun 10 08:00:08 LittleDude logrotate[21951]: error: found error in file sssd-common, skipping
Jun 10 08:00:08 LittleDude systemd[1]: logrotate.service: Deactivated successfully.
Jun 10 08:00:08 LittleDude systemd[1]: Finished Rotate log files.
D4-320
rfbjr
Post by rfbjr »
General update question, if for example CloudSync was updated, would it be mentioned in the release notes or will just the indicator next to the app indicate "New".
D4-320
imranalam
Pakistan
Post by imranalam »
plz share down load link for local upgrade, I am unable to get login screen now
MikeZhang
Post by MikeZhang »
imranalam wrote: 11 Jun 2026, 00:34
Please confirm if you can't login NAS or can't update TOS version?
imranalam
Pakistan
Post by imranalam »
MikeZhang wrote: 11 Jun 2026, 07:49
after updating to TOS 7.0.0612 Beta (X86)
snapsh0t
Post by snapsh0t »
Successful update from 7.0.0616 to 7.0.0706 but the IPV4 network status is showing as down from NAS to router which is obviously wrong given that the update was successful. I noticed this in 7.0.0616 as well.
