TOS 6.0.783 (X86) is Released for Update
bartmans99
Netherlands
Re: TOS 6.0.783 (X86) is Released for Update
Post by bartmans99 »
TMzethar wrote: 30 Sep 2025, 16:23
bartmans99 wrote: 29 Sep 2025, 18:36
We have not yet observed similar issues caused by this update. If you are running a large number of services, it is likely that the Docker service has not yet started successfully.
We recommend waiting for a while longer and then observing the situation.
No, this is not the case. The Docker engine won't start automatically and has to be manually enabled. Even if I wait an hour or so.
EthanLiu
Post by EthanLiu »
bartmans99 wrote: 07 Oct 2025, 01:46
Thank you for your feedback. Due to differences in our environment, we are unable to reliably reproduce the situation you described. If you encounter this issue again, please try exporting the system logs and sending them to us. We will also follow up on this issue and conduct verification in our lab.
spleenrun
France
Post by spleenrun »
Hi everyone,
I’ve seen that a new TOS update has just been released.
However, it looks like many users are still experiencing issues after installing it.
For those of you who own an F6-424 Max,
👉 Has anyone successfully installed this latest update without problems?
I’d love to hear your feedback before I consider applying it myself — I’ve already been through enough headaches with the previous version 😅
Thanks in advance!
mmick
Portugal
Post by mmick »
TMzethar wrote: 29 Sep 2025, 15:05
mmick wrote: 29 Sep 2025, 00:57
We have noticed and replied to your post on the 6.0.770 update topic.
Does this SSD have similar issues when connected to a PC (NTFS/FAT32/exFAT) or a Mac (APFS/exFAT) or others linux system?
If you have not observed similar anomalies on other systems, please provide the SSD model number and schedule an engineer for remote inspection via the official website's Live Chat (please mention the URL of this post).
www.terra-master.com
On Linux, Windows or Mac, I have no such issues.
Affected SSDs:
- Samsung T7 2 TB + T7 Shield 2 TB
- several NVMe drives (from 512 GB to 1 TB, several brands) in external enclosures (several brands)
- I tried several cables
All drives:
1 partition
If formated in exFAT (NAS or PC) problems appear at begining or while copying.
If formated in NTFS everything is ok
I have a 3 TB HDD permanently attached over USB , formated in NTFS and no issues.
If I have to say: exFAT support, at least over USB and with big capacities, is broken.
Lusky1971
Italy
Post by Lusky1971 »
Update successfully on my F2-422 with 2 HDD Seagate IronWolf 4TB/8TB
billyBob
Switzerland
Post by billyBob »
Updated F5-221 from .770 -> .783.
When I opened file explorer to check the Volume1 folder, it was not there. I had to reload the browser and then it appeared. After turning on security isolation and rebooting, I logged in and had to reload the browser again to see the control panel and other things.
Everything else was normal. I use a static IP assigned to my Nas and did not test any dhcp issues.
TOS 6 rocks imo.
spleenrun
France
Post by spleenrun »
spleenrun wrote: 07 Oct 2025, 23:12 Hi everyone,
Thanks in advance!
F6-424 Max UPDATE: OK :D
tronesmethod
Norway
Post by tronesmethod »
Update went ok on a F2-223 :) Was still on older TOS 5 version so had to update to last 5 version, then first specified 6, then 6.0.780 and then finally this one !
luismartin
Post by luismartin »
This isn't just a question for 6.0.783, it applies to all other updates.
I have TOS installed on only one M.2 drive, but not on any of the 12 drives in my T12-450.
Would I have less risk of RAID data loss by disconnecting all 12 drives, updating the M.2 drive, shutting down, and reconnecting the drives again?
luismartin wrote: 14 Oct 2025, 06:41 This isn't just a question for 6.0.783, it applies to all other updates.
Version 6.0.783 has added a system disk management feature. You can update the system separately on the M.2 drive and then insert other HDDs.
