TOS 6.0.648 (X86) is Released for Update
PLOPZA
Re: TOS 6.0.648 (X86) is Released for Update
Post by PLOPZA »
Hello, I just updated to .648 from the previous build and I am unable to login to the terminal from the webui, or start plex from the app center. It seems to be python related, I did fix it in the previous update. I didn't record or remember to write down the solution. Also remote access outside the LAN doesn't work.
EthanBerg97 wrote: 02 Mar 2025, 17:25
The Cloud Sync app now supports both cloud storage platforms you mentioned. In the future, we may add support for more cloud storage platforms as needed.
tanktarta
Post by tanktarta »
I think my TNAS is quite sick after that update. As well my still unsolved domain joining problems, there are a few other concerning things. The scariest of which is I have just noticed that TOS is reporting both of my volumes as corrupted.
However, they are both mounted as read/write and seem to be fully usable. Nor could I see any evidence in `dmesg` of any btrfs errors. It looks like it is incorrectly detected corruption.
The second thing is, the `ssh` command no longer works on the NAS itself if i `ssh` to it This always used to work, and is suggesting something else is wrong.
superuser@terra:~# ssh
OpenSSL version mismatch. Built against 30000020, you have 30300000
superuser@terra:~#
The final thing occurs when you try to launch any application from the web UI. Most of the time, it will immediately popup a dialog to say that the application has failed to launch, but it actually does launch.
I tried to enable "Debug Mode", but it wont let me select any disk for the debug logs, presumably because it thinks the disks are corrupted.
EDIT: I have found the cause of the ssh command failing at least. This is happening because the LD_LIBRARY_PATH environment variable is set to :/Volume1/@apps/LogCenter/lib:/Volume1/@apps/MultimediaServer/lib:/Volume1/@apps/Surveillance/lib in a root shell (anyone know why?). However, there are libraries in Surveillance/lib that are of different versions to those in the main /usr/lib/x86_64-linux-gnu directory. There doesn't appear to be any updates to surveillance manager. So for now, the work-around is to use
LD_LIBRARY_PATH= ssh user@host
or uninstall the surveillance manager. This hasn't helped with any of the other problems.
Lex
Post by Lex »
Gremlin wrote: 02 Mar 2025, 06:08
Lex wrote: 01 Mar 2025, 20:07
Experience tells me that the TOS network interface cannot be changed unless it is active. After modifying interface if the dialogue appears, wait a little then refresh the browser.
NAS work more than 1 day.
Also I can`t see on-line users.
After that window does not respond. I need reload page, for use settings.
F4-423
plexjellyfin
Post by plexjellyfin »
this update broke Plex for me
jpeckinp
Post by jpeckinp »
plexjellyfin wrote: 04 Mar 2025, 11:17
Plex is working fine for me. You checked all your settings?
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
sianderson
Post by sianderson »
jpeckinp wrote: 04 Mar 2025, 11:34
i agree plex is fine for me after the update 610 to 648 also
F2-424 TOS 7.0.1169
F2-423 TOS 7.0.1169
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
HeliaWu
Post by HeliaWu »
"Try this method and see if it works for you: viewtopic.php?t=4772"
PLOPZA
Post by PLOPZA »
UPDATE: I made a backup of preferences, then reinstalled TOS from factory settings, That fixed my issues.
Note: my NAS had issues with python losing a symlink somewhere on the system, re linking the bin fixed Plex, Smb being unable to activate, and terminal issues within the webui,but those Issues existed on a prior TOS6 build, I didn't write down which one though
jpeckinp
Post by jpeckinp »
Is the update page working? The last few days when I login it says it couldn't check for update and to check my settings.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
