TOS 6.0.577 (X86) is Released for Update
Re: TOS 6.0.577 (X86) is Released for Update
spaceman wrote: 06 Jan 2025, 22:51 I can't mount Windows and WD Cloud shares using Remote Folder. I'm geting error remote source path unavailable.
I can easily mount through shell and mount -t cifs
Please refer to the mount example shows on the UI and make sure your information you input is correct.
Oversizewizard wrote: 07 Jan 2025, 00:12
All the 3rd party apps must be adapted to be compatible with TOS6. Wait for a new tpk with TOS6 in the file name.
anxo
Spain
Post by anxo »
Hi everybody.
I'm trying to install the last TOS 6 version on my F2-423 nas but when I go to System update no new version of TOS 6 is detected for automatic install on the nas. My current TOS version is 5.1.67 and the BIOS/initBoot version is 5.19
Thanks!
liability
Australia
Post by liability »
anxo wrote: 09 Jan 2025, 04:11 Hi everybody.
Thanks!
Unless you can find a copy of one of the earlier versions, such as 6.0.420 and install that first, you won't be able to update to the current 577 version until Terramaster releases a direct update. I have a copy of the 420 version if you want me to upload it somewhere for you, but it might be safer to wait a couple of months until Terramaster release a direct update.
Thanks!
A correct update path for your model is: 5.1.67 -> 5.1.145 -> 6.0.530 -> 6.0.577
Thanks!
You can refer to the following content: viewtopic.php?t=6984
anxo
Spain
Post by anxo »
Thank you all for your help
sae24
Post by sae24 »
TMroy wrote: 09 Jan 2025, 15:09
where I may find right way to upgrade my F4-422?
sae24 wrote: 10 Jan 2025, 01:24
From which version?
OttO1916
Netherlands
Post by OttO1916 »
Hi.
No idea if it's related to 6.0.577, but fact is that after the update when I copy files to my F5-221 using SMB the system performance goes from smoothly to sluggish after a few seconds. Copies with some 50Mbps max. That would be OK using 100Mbps, but not for 2500Mbps. Any suggestions plz?
F5-221 - TOS7.0.1140 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1140 - 2x3TB JBOD - 1x4TB Single USB
