TOS 6.0.507 (X86) is Released for Update
norman0
Germany
Re: TOS 6.0.507 (X86) is Released for Update
Post by norman0 »
TMRyan wrote: 30 Sep 2024, 15:43
norman0 wrote: 30 Sep 2024, 12:43 Is this version work on the F2-220?
This model no longer supports using TOS6.
What happens, if I try to use?
F2-220 4GB + 2*Seagate IronWolf 4TB
Bartman
Post by Bartman »
Any chance of using our own SSL certs for HTTPS? it was promised to be in TOS 6. As it always comes up not secure using the TerraMaster webserver software using Let's Encrypt certs as well as TerraMaster's certs.
Kind Regards
F2-423
TOS 7.0.1105 (X86) (Still in Beta as there are way to many problems)
Tom
Ireland
Post by Tom »
I have a F5-221 and through the many updates of TOS 6 beta now at TOS 6.0.507
I have some issues
1) I can no longer turn off the NAS it just reboots and comes back on.
2) the APP button doesn't display the application menu. I can open the apps from short cut on main page.
3) UPS works after a reboot for a short time then becomes disabled in the UPS menu. This is of concern to me as I'm using the NAS as NUT server.
My NAS was manafactured in 2021 and I have upgrade the RAM by 8GB CPU usage is very low RAM usage is also low at less than 20%
As I'm not seeing other users with this issue I wondering if I should revert back to TOS 5 or wait until TOS 6 is updated with fixes ?
Bartman wrote: 04 Oct 2024, 22:01
If you do not want the browser to prompt security information, you need to bind your newly applied certificate with your TNAS domain name or IP address. I hope you are familiar with these operations.
Tom wrote: 05 Oct 2024, 07:01
which beta version before you update to 6.0.507? it seems the system is not fully functional or fully updated.
titan5
Post by titan5 »
Hello TMroy, could you please reply to this post over in the earlier Update Thread:
viewtopic.php?p=38548#p38548
owen94
Malta
Post by owen94 »
I've updated from 6.0.500 and am now being prompted with the TNAS Initialization page. I DO NOT have ssh enabled so I cannot do the CheckSystem part. I never modified any files through SSH, infact I have always left it disabled and used the GUI. What else can I do?
owen94
Malta
Post by owen94 »
owen94 wrote: 05 Oct 2024, 17:33 I've updated from 6.0.500 and am now being prompted with the TNAS Initialization page. I DO NOT have ssh enabled so I cannot do the CheckSystem part. I never modified any files through SSH, infact I have always left it disabled and used the GUI. What else can I do?
Where can I find this package?
owen94 wrote: 05 Oct 2024, 17:36
Which model of nas?
You can try searching here: https://support.terra-master.com/download
F5-221 TOS7.0.1188 - 4x4TB (Ironwolf) Traid
F2-424 TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1188 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
owen94
Malta
Post by owen94 »
Gremlin wrote: 05 Oct 2024, 18:01
F4-423.
There is no version 6 available for download on the support page...
