{L_BUTTON_AT}great0dane
You can try to clear the cache records of SMB access on your computer. You can refer to this link: viewtopic.php?f=77&t=2743&p=14974&hilit=%2Fdel#p14974TOS 5.1.103 (X86) is Released for Update
Re: TOS 5.1.103 (X86) is Released for Update
- great0dane
Thank you for suggestion but that does not fix issue, the missing Shared Folder is still not restored on the F5-422. The data is saved on the disk but the F5-422 will not make the folder so I cannot use the files.
Please check whether you also have a shared folder named "NAS" on Volume1. If it exists, you can follow this operation guide: viewtopic.php?f=81&t=4598 (Note that replace the volume name and shared folder name in the operation guide )To contact our team, please send email to following addresses, remember to replace (at) with @
{L_BUTTON_AT}TMwuu
Doesn't help:
After clearing all Safari browser data (+ history) the TOS control panel still shows NaN.NaN.NaN for date and time. My iPad iOS version is 17.2 (current).F2-220, OMV 7.5, Docker (Nextcloud, AdGuard Home, immich, File Browser, Stirling PDF)
- great0dane
{L_BUTTON_AT}TMwuu
{L_BUTTON_AT}topo01
You can log in with another browser on your iPad to see if it is displayed properly.
{L_BUTTON_AT}TMqiky
The issue persists:
I just installed Firefox, Chrome and Opera on my iPad and all three show the exact same as Safari with NaN.NaN.NaN for date and time.F2-220, OMV 7.5, Docker (Nextcloud, AdGuard Home, immich, File Browser, Stirling PDF)
{L_BUTTON_AT}TMqiky
And it is the same on a totally different iPad. On Windows (Chrome and Edge) it's all good. At the moment this issue is only cosmetic for me and not a real issue.
- Grimsbeard
Imagine my total shock when I decided to get 5 fresh 20TB drives and load them into my F5-221, when I was like "you know what, I am going to see if there's an update." I went to the website, to support and downloads and bam, there's 5.0.176. Amazing! Well, I didn't know the forums were more reliable for updates, but I digress.
The 5.0.176 had my fans stop working entirely and I had so many headaches with it. Yesterday I decided to say forget it, read up more and found this release and it needing 5.1.24. So, I did a factory reset, fans started to work and then updated up to this version. Thank god.
let me just say, building out a RAID5 with 4 drives and a spare without fans running was... an adventure. So if you have issues with fans, the drive lights all red, fans not spinning, I strongly recommend reset and load the .24 release first, then upgrade.
Just to point this out - 5.1.103 is newer than "5.0.176 and 5.1.24"Grimsbeard wrote: ↑11 Jan 2024, 16:33 Imagine my total shock when I decided to get 5 fresh 20TB drives and load them into my F5-221, when I was like "you know what, I am going to see if there's an update." I went to the website, to support and downloads and bam, there's 5.0.176. Amazing! Well, I didn't know the forums were more reliable for updates, but I digress.
(Guess you just looked at the last 3 digits)
