TOS 5.0.158 (x.86) is Released for Update
crisisacting
Re: TOS 5.0.158 (x.86) is Released for Update
Post by crisisacting »
@YuckFou
viewtopic.php?f=28&t=3637&sid=9c7571ad1 ... f&start=20
The integrated multimedia server has an issue, so they pulled it.
If you don't use that feature, then you won't notice the issue.
txhousa
Post by txhousa »
{L_BUTTON_AT}txhousa
TMSupport wrote:
> Which apps are you using?
It is CloudSync. The established connection to Google Drive was lost. Moreover, each time I log in, I see this app does not run and sync to my Google Drive and I have to manually enable it in App Center.
jparker98
Post by jparker98 »
{L_BUTTON_AT}jparker98
TMroy wrote:
> May I know what kind of USB? did you set the permissions on UI
> successfully?
1 WD 4tb external
1 WD My Book Duo external raid
I can access them fine via my admin account, when I try to give the "media" usergroup read/write it goes through fine, but if I open edit again immediately after it's defaulted back to deny.
Thank you for your report! This is a bug, we will fix it soon.
jparker98
Post by jparker98 »
Sounds good, thanks!
kenfrog
Post by kenfrog »
Anyone else catch the newest update ? My F5-422 patched to TOS : 5.0.163-00210 this morning
seems fine - have not noticed any issues but the fourm post about this release is nowhere to be found : )
Cheers Mates
Gandalf1369
Post by Gandalf1369 »
Saw the same notice. Updated my F4-220 to TOS 5.0.163 this morning. Had a few issues being able to access the TOS desktop from the WebUI but that cleared up after two reboots. So far everything is working fine.
jparker98
Post by jparker98 »
Installed the 163 update and still have the usbshare permissions issue :(
chalnoth
Post by chalnoth »
I went ahead and installed 163 (from 160) and wish I hadn't on my F4-422. NAS is now offline i.e. web console is not available (/tos/#/ page is blank), CIFS shares and docker apps are not running.
Last messages on the console are
[DEBUG Failed to find entry for user guest.
CMCI storm subsided: switching to interrupt mode
I have tried a couple of hard resets as that has helped in the past but not this time it seems.
chalnoth
Post by chalnoth »
UPDATE: never mind - seems I should have waited another 15 minutes. So much for the 5 minutes countdown. A reboot is very slow it seems.
> this time it seems.
