[ ZeroTier ] Securely connect any device, anywhere
doctorase
Re: [ ZeroTier ] Securely connect any device, anywhere
Post by doctorase »
Hi, I'm using F2-221 and i want to do a connection with ZeroTier. I've installed the app in my NAS and i've introduced the ZeroTier adress to ZeroTier network like i did with my android smatphone. The smartphone shows online, but the NAS adress show unknow and i don't know if it's connected correctly. Also I can't enter to http(s)://yournasip:port/modules/ZeroTier/www changing yournasip:port for my nas ip and port. It shows a message with 404 Not Found nginx 1.18.0
What can i do?
arqweryon
Post by arqweryon »
If you SSH into your NAS and check using:
zerotier-cli status
What does it show?
doctorase
Post by doctorase »
It shows this:
200 info 5a7aa98ead 1.10.2 ONLINE
up to 1.10.3.0
juan26felipe
Post by juan26felipe »
{L_BUTTON_AT}outkastm
Hello, I'm still trying to use the application but it has the same error, please can you confirm what it could be. The installation is being generated in an F2-210 arm64 I share the image of the error, it connects to zerotier but the error 500 of the execution is not effective. I would greatly appreciate your support.
sorry i have no arm device to test this app.
Can be that some kernel modules are missing in TOS
viewtopic.php?f=37&t=2713&start=30#p22652
up to 1.10.6.0
juan26felipe
For arm it will not be updated anymore?
far as i know is not working on arm due to some missing kernel modules probably.
I have no device to test.
Noco
Post by Noco »
[at=outkastm post_id=14740 time=1638061394 user_id=2797][/at]
Sorry for the question, I'm not a programmer and I can't connect my nas with zerotier, I added the address that creates the app but I don't know what else I have to reprogram.
in the authtoken file there is the right address but then in the zerotier dashboard I don't see it connected.
I really need help!!! :shock:
