[ Jellyfin ] The Free Software Media System
trix81
Re: [ Jellyfin ][ 10.8.0.0 ] The Free Software Media System
Post by trix81 »
Any news for jellyfin and tos5?
Developer tool has been released today.
Jellyfin for TOS5 will be available around 13/07
scout71
Italy
Post by scout71 »
I have a doubt ... installing TOS5 also has to redo all the configurations of the installed apps? I use Jellyfin and Nextcloud a lot. If I think I have to do it all again, it hurts me ...
Unfortunately TOS5 is tootally different than TOS4 with different path structure.
But you can always backup database, Nextcloud data folder, and Jellyfin config directory to restore them in TOS5 after you install the apps
scout71
Italy
Post by scout71 »
Being a super newbie, would you tell me what the folders are exactly? I saw that in Nextcolud there is an app but it is not compatible with version 24 so I will have to do it manually. Does the database also have a particular application or does it reside in a specific folder? Sorry but I'm really clumsy on these things.
Will check this evening
Re: [ Jellyfin ][ 10.8.1.0 ] The Free Software Media System
up to 10.8.1.0 and added TOS5 version
MisterXY
Germany
Post by MisterXY »
I can't install jellyfin, modbase,ffmpeg, oracle java. I always get the warning that the file is wrong.
Have TOS 5.0.130
Have you download the tpk files from folder TOS5?
MisterXY
Germany
Post by MisterXY »
Ah ok I thought it already tells me I'm in the TOS 5 folder. Failed to install it now was my fault.
