[ Syncthing ] Continuous Replication/Cluster Sync
Scorp
Re: [ Syncthing ] Continuous Replication/Cluster Sync
Post by Scorp »
Worked like a charm in 5.1.12, but stopped working in 5.1.13. =(
what exactly doesn't work ?
Tested here on 5.1.13 and no issue
Scorp
Post by Scorp »
Had some problems with permissions. Deletening main folder and reinstalling without saving docs helped.
lincooln
Post by lincooln »
does not work. version 1.22
installed on TOS 5.1.17
Error 502 Bad Gateway
Can be that php-fpm is not running on your device.
Try this fix viewtopic.php?f=37&t=4171#p24418
scout71
Italy
Post by scout71 »
Hello, sorry for the inconvenience, I had to update to the latest TOS 5.1.34 (I say "I had to" because usually if everything works I tend not to touch the operating system). Now everything seems to be fine except Syncthing won't start. The installation is successful but the service does not start anymore (it was fine before). Having updated it, in practice it has all the configuration already done... I tried to install and uninstall but it still doesn't work... I would only have to physically delete everything concerning it but if possible I would like to avoid it to keep all the configuration that I laboriously I set a while ago. Do you have a solution? I also tried to see the solution for the bad gateway but that's not what it seems. Thanks again for the help and support
will be updated to work with latest TOS
updated
scout71
Italy
Post by scout71 »
A thousand thanks! Everything works.
jgea
Post by jgea »
I installed it in 5.1.37 and it does not work.
The app says it started, however I cannot access the UI, and in the log I see this:
[start] 2023/06/30 17:39:46 INFO: Generating ECDSA key and certificate for syncthing...
[start] 2023/06/30 17:39:46 WARNING: Failed to load/generate certificate: save cert: open /usr/local/@APP_CONFIG/SyncThing/conf/cert.pem: permission denied
[monitor] 2023/06/30 17:39:46 INFO: Syncthing exited: exit status 1
[monitor] 2023/06/30 17:39:47 WARNING: 4 restarts in 4.109617831s; not retrying further
After this the application stops and it does not work.
Any idea on how to fix it?
Thanks!
