enryx wrote: ↑Today, 06:04
After upgrade to TOS 7 login page shows TOS 6 label instead of TOS 7.
Take a look to the image attached.
Based on the screenshot you provided, the version number is unexpectedly 7.0.1341.
It appears that you skipped the required intermediate update to version 7.0.747 and went directly to 7.0.1341.
This is not the correct update process and may cause some unknown issues.
You may want to consider the following steps to restore normal operation:
Remove the side panel of the F6-424, take out the built-in USB Initboot, and flash the TOS7 UEFI image.
viewtopic.php?t=6433
Reconnect the USB Initboot to the NAS, reset the system, and proceed directly with the initial installation of the latest TOS7:
viewtopic.php?t=9523
