Can you use TNAS PC to find the NAS? Will there be any error messages when entering the NAS's IP address or tnas.local in the browser address bar?
TOS 7.0.0392 Beta (X86) is Released for Update
Re: TOS 7.0.0392 Beta (X86) is Released for Update
After updating my F2-221 from 06.0.794 to 07.0.0299 the NAS would not start. The USB Drive Image was defect, so i had to install a new image on the USB Drive. Now the NAS works and an update to 07.0.0392 works without problems. Update on F4-425 works without problems.
Both NAS devices are working normally, except for the hard drive sleep mode.
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
- koalakoala
Hi TM team, may I ask for the direct link to the latest " update package" topic on this forum (from the next version, please)... can you make this one available in the same way as version *.299 in viewtopic.php?t=9437. i.e. This is not available in the same way for TOS 7.0.0392 (in this discussion, this page, link: viewtopic.php?t=9655)
I am sending this message because "1.Go to TOS > Control Panel > General Settings > System > Update, and click "Check for updates."" is not working (I got a message saying there is a network issue.
Providing the "update package" links in these discussions will certainly improve customer experience.
Thanks.
Thanks.
Thank you for your feedback. I will relay this requirement to the product team for evaluation.
This is the anti-cheat verification function, which has nothing to do with the TOS system itself. You can clear your browser cache or switch browsers, then try to log in again.
The issue where updating the system would reset the hibernation settings has been fixed. Please wait for future version updates.
After updating to TOS_X642.0_Update_7.0.0299_00446_2512081654.bz2, the system does not start completely. Please tell me what to do to revive it
F-423
From which version did you upgrade to 0299? What else did you do?
From your screenshots, it looks it boots into iniboot, you need to reinstall TOS as per our instruction below viewtopic.php?f=76&t=423
I updated from TOS_X642.0_6.0.794.MikeZhang wrote: ↑06 Mar 2026, 17:41From which version did you upgrade to 0299? What else did you do?
F-423
