TOS 6.0.794 (X86) is Released for Update
Re: TOS 6.0.794 (X86) is Released for Update
Reminder wrote: 06 Dec 2025, 21:31
Within system / harddisk overview I found several partitions on the SSD:
Those numbers are normal.
- sdza1 - VFAT - 285M (seems to be the system itself): BOOTLOADER
- sdza2 - "RAID-Member without independent Data-System" (translated by myself) - 7,6G: OPERATING SYSTEM
- sdza3 - "RAID-Member without independent Data-System" (translated by myself) - 1,9G: SWAP
- sdza4 - "RAID-Member without independent Data-System" (translated by myself) - 455,8G !!!!!: DATA (ie a VOLUME)
F5-221 TOS7.0.1188 - 4x4TB (Ironwolf) Traid
F2-424 TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1188 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
Reminder
Germany
Post by Reminder »
There is no Volume or Data placed by myself. These SSDs are ONLY for System. And that enormous amount of Data that filled the SSD to 100% occurred only after the system update to 6.0.794 (from 6.0.783).
So the questions are: how to delete that data, how to access the partiton? And additional: how to avoid that problem in the future?
Reminder wrote: 08 Dec 2025, 19:59
Please generate and download the log report in TOS > Technical Support > Issue Report, then send it to our technical support email ([email protected]). We will analyze it.
While I said "Data" maybe I should have said "space allocated for data". It does not need to have actual data in that space. The 455.8GB is the partition size which can be which can allocated to 1 or more Volumes, (shared) folders are generated maybe by user or system and then data is placed on them. Sometimes apps are installed here (at the choice of the admin-user) and sometimes things like snapshots are stored here.
Polo
France
Post by Polo »
There is a bug, when i'm connected on my Cyberghost VPN my IP WAN disappear on the right control panel and appear if i deactivate it !
Polo wrote: 09 Dec 2025, 19:32 There is a bug, when i'm connected on my Cyberghost VPN my IP WAN disappear on the right control panel and appear if i deactivate it !
Hello, we have noticed this issue and it will be fixed in the next version.
MapaM
Spain
Post by MapaM »
At first glance, everything seems to be working fine on an F6-424
F6-424 + D4-300
wilson
Singapore
Post by wilson »
Help! F2-423. I updated from 770 to 783. Saw another update and updated to 794.
Now I can't access it via local IP. I can ping it. I used TNAS mobile to detect it and it shows uninitialized. Clicking in, it shows a page that TNAS initalization is starting soon.
I have data in my current disks. Is there any way to restore?
wilson wrote: 16 Dec 2025, 21:13
It seems the last startup did not successfully launch TOS. You can try restarting multiple times to see if that helps. Also, check if there is a disk that is not securely installed in its slot.
If the problem persists, you may consider resetting the system. (Please note not to select a disk that was previously used as an SSD Hyper Cache as the target for system installation.)
It is recommended that you check the disk.
akaserge
Post by akaserge »
I'm trying to update version from 6.0.770 to 6.0.794. After the message "unzipping, wait" nothing happens. What can be done?
The update was successful on the second try.
Model F2-221 TOS Version 6.0.794
