TOS 6.0.673 (X86) is Released for Update
TMbuddy
Re: TOS 6.0.673 (X86) is Released for Update
Post by TMbuddy »
vignatiev wrote: 24 Apr 2025, 00:05
We sincerely apologize for the inconvenience! Our technical team has successfully reproduced and confirmed the issue you reported regarding Volume and Hyper Cache. This defect will be fixed in the next update as soon as possible. Please note that the SSD cache you configured is currently only effective for Volume1. Thank you very much for helping us improve our product!
OttO1916
Netherlands
TOS X.X.XXX (X86) is Released for Update - Issues
Post by OttO1916 »
Just a suggestion: If after a new release some confirmed/reproducted issues appear that will be addressed in a future release, then edit the first "TOS X.X.XXX (X86) is Released for Update" forum entry and add that info there. Like this there is no need to go through the entite thread?
F5-221 - TOS7.0.0777 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.0777 - 2x3TB JBOD - 1x4TB Single USB
FredMutter
France
Re: TOS X.X.XXX (X86) is Released for Update - Issues
Post by FredMutter »
OttO1916 wrote: 24 Apr 2025, 19:35 Just a suggestion: If after a new release some confirmed/reproducted issues appear that will be addressed in a future release, then edit the first "TOS X.X.XXX (X86) is Released for Update" forum entry and add that info there. Like this there is no need to go through the entite thread?
I second that. Alternatively, you could add a second (nearly empty) post titled “Known Issues with This Release” containing just one line: “None.”
And just edit it later as bugs come up.
Model: F2-424 with TOS 7.0.0777 Bios V08
FredMutter wrote: 24 Apr 2025, 20:02
What they said :)
jositodc
Spain
Post by jositodc »
TMroy wrote: 24 Apr 2025, 09:37
jositodc wrote: 24 Apr 2025, 07:12
Gremlin wrote: 23 Apr 2025, 21:48 If you are seeing 'local' as being a problem I wonder if this is geographical blocking on one side or other.
The problem may be geographical, we're waiting for Terramaster to respond, as it's not working for many users.
Your information is incorrect. You can check the forum records; since the release of version 6.0.650, you are the first to report that the email notification feature is not working. Anyway, please cooperate with us as we investigate your case.
In this same thread on the first page, user Seb also has this problem. In the 650 update thread, there were also people with this problem.
TNAS F2-221 / 6.0.783 8-)
TMbuddy
Post by TMbuddy »
Thank you very much for your suggestion! We will give serious consideration to your proposed needs.
TMbuddy
Post by TMbuddy »
jositodc wrote: 24 Apr 2025, 20:45
We sincerely apologize for the inconvenience. Your reported issue has been escalated to our technical team for verification. If confirmed, we will prioritize a fix at the earliest opportunity.
sianderson
Post by sianderson »
updated, other than upon rebooting it decided to get another IP address from the DHCP which caused a little confusion but once set to static all was good, it seems to be working and no issues so far
F2-424 TOS 7.0.0777
F2-423 TOS 7.0.0777
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
sianderson wrote: 25 Apr 2025, 02:06 updated, other than upon rebooting it decided to get another IP address from the DHCP which caused a little confusion but once set to static all was good, it seems to be working and no issues so far
What did you mean? why the new IP from DHCP got you confused?
Polo
France
Post by Polo »
Since this update my VPN configuration are not working and when I put my login / password and configuration key I have an error, impossible to make it work, I use the openvpn configuration from file... What should I do? I need help my NAS is a F6-424 Max
