TOS 6.0.577 (X86) is Released for Update
IrisLi
Re: TOS 6.0.577 (X86) is Released for Update
Post by IrisLi »
TheBacons wrote: 29 Dec 2024, 03:46
Try restarting nginx service.
Log in to the TNAS terminal with ssh as root, execute the following instrcution:
viewtopic.php?f=78&t=2350
Enter the following command:
systemctl restart nginx.service
Refresh the TOS page.
mmedic
Post by mmedic »
Hi! Can anyone confirm that system e-mail notification are still can be sent through local server to admin`s e-mail? Or I am doing something wrong because on TOS5(145) notifications worked fine for me through local server.
F4-424, actual TOS6
As far as I know "local" setting is still 'broken' (for a lot of users) in TOS6. Use "custom" and set TLS/SSL with appropriate ports for your mail service.
mmedic
Post by mmedic »
Gremlin wrote: 30 Dec 2024, 06:14
Already done in the same way! Thank you for the response.
F4-424, actual TOS6
DekkaR
Iceland
Post by DekkaR »
TM F8 SSD: 8GB RAM: 9 TB TRAID EXT4: TOS 7:
TM F8 SSD Plus: 32GB RAM: 4TB RAID0 EXT4: 2TB RAID0 EXT4: TOS 7:
TM F4-425 Pro (N350): 16GB RAM: 8TB RAID0 EXT4: 6TB RAID5 EXT4: TOS 7:
[ DekkaR ]
We are working on a new solution, please wait.
rigveda
Post by rigveda »
Does it support Model: F5-221 yet? Or is there a documented upgrade path I need to follow to get to an interim version to get to the latest version i.e. an older version then to the latest version?
liability
Australia
Post by liability »
rigveda wrote: 06 Jan 2025, 01:26 Does it support Model: F5-221 yet? Or is there a documented upgrade path I need to follow to get to an interim version to get to the latest version i.e. an older version then to the latest version?
I have several F2-221 units and installed the 6.0.420 update and then it auto updated to the 577 current version. I assume that will also work for the F5-221, as I believe the only difference is the 2 versus 5 drives.
spaceman
United Arab Emirates
Post by spaceman »
I can't mount Windows and WD Cloud shares using Remote Folder. I'm geting error remote source path unavailable.
I can easily mount through shell and mount -t cifs
Oversizewizard
Post by Oversizewizard »
Update my 221 to latest 577. Everything seems to work fine apart from two apps.
Home assistant, try to open and it says access denied, need to log is as admin.
Any suggestions.
Tried on the second account I have on there as admin and same error.
