TOS 5.1.103 (X86) is Released for Update
BorizzK
Re: TOS 5.1.103 (X86) is Released for Update
Post by BorizzK »
F2-423
5.1.95 -> 5.1.103
with no problems
all settings preserved, inc bond (lacp), ModBase, Midnight Commander etc.
topo01
Germany
Post by topo01 »
In 5.1.103 I still see the issue with date and time that the system shows NaN:NaN:NaN if format dd.mm.yyyy is selected (standard for my region).
Strangely this only happens on my iPad. Everything seams fine on other devices (Chrome on windows and Opera on Android).
F2-220, OMV 7.5, Docker (Nextcloud, AdGuard Home, immich, File Browser, Stirling PDF)
TMlinda
Post by TMlinda »
{L_BUTTON_AT}topo01
You can try clearing your browser cache.
great0dane
Post by great0dane »
F5-422, updated from 5.1.67 to 5.1.103
Shared folder has failed to restore. Data has become uncategorized, inaccessible partition on volume.
what is your system partition size? check this:
viewtopic.php?f=28&t=4912
great0dane
7.41GB
Your volume 2 is located on your storage pool 1? how you configure your storage pools 1 and 2? I saw another 90GB volume with ext 4, is this volume alos locate on storage pool 1? did you try to restart the device and restore your shared folders?
great0dane
Yes two storage pools, they are on different disks:
Volume 1 = 100GB EXT4, Storage Pool 2, SSD Single Disk
Volume 2 = 27TB BTRFS, Storage Pool 1, 3x HDD RAID0
One of the Shared Folders on Volume 2 will not restore. Restarting does not help restore the missing Shared Folder. I have set Shared Folder to restore to Volume 2 per the settings-
Is the shared folder have the exact same name as "public"? or is it under your personal home folder?
great0dane
The folder was named "NAS". I disabled user home folders in the settings. I can still see this folder in Windows network folders but cannot access, it gives me error message.
