TOS 5.1.95 (X86) is Released for Update
joka388
Austria
Re: TOS 5.1.95 (X86) is Released for Update
Post by joka388 »
{L_BUTTON_AT}joka388
TMzethar wrote: 24 Nov 2023, 19:42 We will verify the issue you mentioned.
Thx. No Problem on the F4-220, 5.1.95 works well and the SMB Speed is at 113 Mb/s with activatet schedules. Problems with SMB Speed only on F2-221 when schedules are activatet.
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
Would it be convenient for us to conduct remote inspections for you?
joka388
Austria
Post by joka388 »
TMRyan wrote: 27 Nov 2023, 10:14 Would it be convenient for us to conduct remote inspections for you?
What date and time?
There may be a time difference, please contact the technical support email or the customer service window on the right side of the official website homepage8 to confirm the appropriate time.
Tricky
Post by Tricky »
Knew i shouldn't of bothered, but curiosity got the better of me so updated from 5.1.67 to 95 and now can't get contact with the unit, initially want visible on network so did the usual reboot, then the re initialise and now still can't contact the unit (F5-221) could initially see it via TOS now can't, or contact through 8181 or 5443!
Tricky
Post by Tricky »
After a lot of faffing about I have managed to reinstall 5.1.67 and can now contact the TNAS but all the HDD indicator lights remain red, can someone tell me what's going on now?
{L_BUTTON_AT}Tricky
An incredible and unheard of situation.
Did you say that even if TNAS is running normally, the hard drive light will still be red?
Perhaps some unknown reasons have caused the problem. You can provide a system report to the customer service or technical support email on the official website homepage for inspection.
StephenNaylor
Post by StephenNaylor »
Updated from 5.1.67 to 5.1.95 on my F5-422
On first startup after the upgrade I waited a few minutes but Plex had not started. I went to the app center and it said that Plex was not enabled. I clicked on the enable button and a few minutes later I got a red operation failed message. I tried that 3 or 4 times as in the past I have seen Plex start on the 3rd or 4th attempt. On this occasion I got a red failure message each time.
I then started to look on the forums to see if anyone else had had the issue and then about 5 minutes later I noticed that my Plex app was showing my content. As per my understanding, all of the attempts I had made to manually "Enable" plex had failed, so this seems to indicate that Plex was already starting up automatically in the background. If that is correct then we could do with better status notification in the app center than "Not Enabled", i.e. "Starting automatically" or something similar.
Anyway, reporting this here in case it helps anyone.
If this happens again, is there a way to check if Plex is already running in the background ?
sae24
Post by sae24 »
Device name: TNAS-F4-422
Model: F4-422
TOS version: TOS_X642.0_5.1.95 after 5.1.76
No issues
JakeF150
Post by JakeF150 »
Model: F2-220
New Install 5.1.95 to get 8g / directory, was running 5.1.41 with 2g / directory
No issues
Model: F2-425, Memory: 16gb, Drives: 2x12tb raid 1, Backup: 5tb usb, 4tb usb, Version: 7.0.0765
