TOS 5.1.67 (X86) is Released for Update
Re: TOS 5.1.67 (X86) is Released for Update
Your RAID or file system could be corrupt. Is your hard drive healthy? Any power failure happened or did you shut down your device without following the shutdown routine?
- thierrys73
{L_BUTTON_AT}TMroy
the disk are ok and i have to press a long time the button power because the tnas has freeze.
i try to repare the system file with your process without success
have you a solution for repare it ?
thanks
Tnas T6-423
Tnas F2-221
Tnas F2-221
- ostaporomo
Hello! Indexing of media files does not work. The checkbox is disabled after pressing the "apply" button
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010 [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
TOS 5.1.79-00214
DAS D4-300
{L_BUTTON_AT}joka388
Finally got around to updating to 5.1.67. I can confirm that setting auto off/start times (enabled or not) does not currently interfere with transfer speeds on my system.
[I did previously do a re-install of 5.1.41 which did not cure the issue.]
F2-422 installation fresh from 5.1.24->5.1.67 and SMB speeds are not normal, i have two HDD, at the HDD the TOS is installed seems like capped to 50MB reading/writing, at the other HDD seems liked capped around 150Mb/sec, which is rather strange, with previous 5.0.xx i had around 200-250mb/sec at both HDD, something is wrong
{L_BUTTON_AT}TMroy
Please write an email to our support team and ask if they can help, or you have to find a service provider locally to rescue your data.thierrys73 wrote: ↑02 Sep 2023, 04:51 the disk are ok and i have to press a long time the button power because the tnas has freeze. i try to repare the system file with your process without success have you a solution for repare it ? thanks
TNAS PC Setup 5.0.35.exe
It is no longer working on "OS Name Microsoft Windows 11 Pro Insider Preview Version 10.0.25947 Build 25947"
I have installed OS 4 times without any additional software on the same hardware that was working.
I installed it as the first item on a clean standard OS!
It installs fine but never finds TNAS F4-421, tried reinstalling and Turning off all firewalls and A/V too.
Regards
Eresen
Regards
Eresen
Kind regards
O.T.Eresen
O.T.Eresen
{L_BUTTON_AT}ERESEN
You can refer to this link to check:viewtopic.php?f=76&t=3815To contact our team, please send email to following addresses, remember to replace (at) with @
Hi! I have updated TOS on my F2-423. After the update, my OpenVPN does not work properly: when I connected to it internet is not working at all, but I can open TOS UI using IP 172.10.11.1.
VPN Server 2.0.49
VPN Server 2.0.49
Please clear your browser cache and try to connect again.
