TOS 5.1.34 (X86) is Released for Update
kg223
Re: TOS 5.1.34 (X86) is Released for update
Post by kg223 »
MDvP wrote: ↑08 May 2023, 15:27 Tested again to update F4-220 from 5.1.33 to 5.1.34, now it works. This time a did not wait the 5 min countdown, close the browser and wait a hour before accessing the TNAS. Maybe a bad timing that the 5 min restart ends up in bootloader.
@kg223: Try to rebuild the media index.
The media index was being rebuilt. It didn't help.
TNAS: F2-223, 32GB Ram, TOS 5.1.41, 1x3TB WDRed ext4
lichkingxxl
Spain
Post by lichkingxxl »
TMroy wrote: ↑08 May 2023, 22:55 Please wait for the file system to finish the job.
20 hours running the process and it's still going on...
I have more than 7.5 Tbytes, will it take much longer?
If you encounter the problem that the webpage keeps showing a blank page and loading after the update, please try this solution.
viewtopic.php?f=76&t=4655
dorsanty
Post by dorsanty »
I got the blank web page for a few hours after upgrading to 5.1.33 but I lost entirely lost the webpage and the file shares after going to 5.1.34.
I've had to do the custom re-initialisation (Method 2 of viewtopic.php?f=75&t=423), and I am now on 5.1.24 with no data loss, and stable for the last 24 hours.
It'll be interesting to see if NAS that used to run 4.x will need a system partition size increase to keep following the 5.x releases.
U8-111 / 5.1.24
jduraper
Spain
Post by jduraper »
Hello, This update have a big bug with the NAS F2-221, I have tried install it two times and in both I had some problem, the update was do from 5.1.33 how a typical update.
in aparece all was ok, but at restart process the app TNAS show IP correctly and when finished all the IP was missing and don't was possible connect with Nas web. And had reinstall from 5.1.24 version to 5.1.33
Pls check it.
lichkingxxl
Spain
TMzethar wrote: ↑09 May 2023, 19:40 If you encounter the problem that the webpage keeps showing a blank page and loading after the update, please try this solution.
This solution dont work for me, SSH session timed out, impossible to connect
Dave11
Post by Dave11 »
Well I tried it but now after a period of time the NAS just stops responding, no HDD activity, no new messages from the console output via HDMI port.
Looks like I'll have to nuke it and start from scratch as it's no good just stalling.
F2-421
Warning! If your initial TNAS system was TOS 4.x, please do not update to this version!
To know more
SquarePeg
Wales
Post by SquarePeg »
Ok, since I can't create a new topic, I had to hijack this one, which is related anyway:
I have a F5-221 with TOS 4.2.40 with my discs in a RAID5 formatted as EXT4. I am considering moving to TOS5 with the discs formatted as BTRFS with the new TRAID feature.
I basically want to know what is the best way to do it. Should I do a fresh install to this version and wipe the discs (I have already backed everything up) or should I install an older version and update to this one?
I have had a bad experience in the past trying to do this and just want to minimize problems.
Thanks in advance
lichkingxxl
Spain
Definitely my tnas is broken, the reinstallation has not worked, I suspect that there is no more space in the partition and my tnas does not respond. Tnas Pc detects it as "unknown", I have managed to open an SSH session but I don't know how to proceed anymore.
Could someone from the Technical Team tell me how to fix it?
