How to reinstall TOS for your TNAS?
Re: How to re-install your TOS?
{L_BUTTON_AT}Madvic
Hi! Please tell more details. What kind of hard disk did you use, what array did you build, and how many volumes did you create?
Did you mean that the shared folder created before cannot be seen in the file manager? If yes, please try the following steps.
1. Go to control panel > shared folder, and then edit permission of shared folder.
If it does not work, try next step.
2. Go to control panel > shared folder > advanced, and then restore shared folder.
Madvic
Spain
Post by Madvic »
It was a single disk RAID volume. Disk is a Seagate Ironwolf 4TB
Now I can not see any of the folders created in it, although I do see that the space is used.
I could check the disk in an Ubuntu computer: I can see 4 partitions, 3 are the ones visible in Terramaster now, the fourth is labeled as "RAID 1" but is unnacessible. I did not perform any operation, just watched.
{L_BUTTON_AT}Madvic
Have you tried the methods mentioned above?
Madvic
Spain
Post by Madvic »
Ok, I changed the mpermissions and everything came back.
Thank you very much for your support!
STERREICHER
Post by STERREICHER »
is there a way to activate the root user (TNAS-???)
My user is deactivated and i cant login via SSH...
in settings there is the check ar "user deactivate" but its grey
{L_BUTTON_AT}STERREICHER
May I know your model number and TOS version?
STERREICHER
its the F5-221 with the newst OS 4.2.18
i solved it when i reinstalled the system without backup the config
some photos and videos are damaged now....
STERREICHER
just a got another problem with NAS....
I updated it from OS 4.2.18 to 4.2.28 in the settings and now i doesnt boot anymore
Status LEDs: everything green (only the LAN ist blinking)
TNAS-xxx.local is loading but keeps having a whitescreen
Hi! Before the update, whether the TOS system is running the vbox application, if so, you need to reinstall the system.
ooremy
Re: How to reinstall TOS for your TNAS?
Post by ooremy »
Will there be updated instructions for those of us that have been .deadbolted? How does one update if we can't get past the ransomware splash screen?
