TOS 5.0.158 (x.86) is Released for Update
Tricky
Re: TOS 5.0.158 (x.86) is Released for Update
Post by Tricky »
Tricky wrote:
> On updating to 5.0.158 I found that it had decided to say they two of my
> drives (volumes) were corrupted, so I deleted and reassigned them, and now
> they are fine, so I am now frightened to update my other TNAS in fear that
> I will lose data.
Anyone else seen this behaviour, the disk report says they are good, and there are no problems once the volume are deleted and remade so what does the problem does the system think the disks are not good or is the update flaky, like I said I am now really worried that the update is going to cause problems on my other TNAS.
thierrys73
France
Post by thierrys73 »
hello
i have a t6-423
many times after a update i must cut the power of the nas if not, it dont restart correctly, even after 40 minutes
after all is ok
TMLyy
Post by TMLyy »
{L_BUTTON_AT}thierrys73
There may be a problem with the system. You can connect the display screen and send the screenshot of the error report to us for analysis.
what did you mean won't restart correctly? what happens? what did you see? any screenshot?
jparker98
Post by jparker98 »
Not able to give the permissions to any of my usbshares...any idea on a timeline for resolution to this or workarounds?
{L_BUTTON_AT}jparker98
May I know what kind of USB? did you set the permissions on UI successfully?
thierrys73
France
> any screenshot?
Hello
in fact there is no detection with tnaspc and no connection with webexplolrer !
even after 40 minutes after the update
thanks
Sorry, again, what did you mean cut of the power? switch off? or just un plug the power adapter?
thierrys73
France
I have to press the buton power many second until the nas stop
Note that the leds of the harddisk( x5 ) have a strong activity at the first restart after the update
But no connection with tnaspc or webexplorer even afer 40 minutes
YuckFou
Post by YuckFou »
Is it bad that I updated to 5.0.160 while it was offered to me through the system's update system? I don't see a thread for the release of it and people are saying here that it was pulled back... while it's still on the server? A link to it: https://download2.terra-master.com/TOS_ ... 231956.bz2
I'm a bit confused about the situation on it.
