[ HomeAssistant ] Open source home automation
Re: [ HomeAssistant ] Open source home automation
Install this via HACS
First install HACS
Then from HACS install Vaillant vSmart
Version: 1.34.0
This is a custom integration
If you have any issues with this you need to open an issue here:
https://github.com/hacs/integration/issues
2024-02-17 15:21:51.398 INFO (MainThread) [custom_components.hacs] Enable category: integration
2024-02-17 15:21:51.399 INFO (MainThread) [custom_components.hacs] Enable category: plugin
2024-02-17 15:21:51.399 INFO (MainThread) [custom_components.hacs] Enable category: template
2024-02-17 15:21:51.399 INFO (MainThread) [custom_components.hacs] Enable category: theme
2024-02-17 15:21:51.399 INFO (MainThread) [custom_components.hacs] <HacsFrontend> Using experimental frontend
2024-02-17 15:21:51.403 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hacs
2024-02-17 15:21:51.412 INFO (SyncWorker_5) [homeassistant.loader] Loaded update from homeassistant.components.update
2024-02-17 15:21:51.415 INFO (MainThread) [homeassistant.setup] Setting up update
2024-02-17 15:21:51.417 INFO (MainThread) [homeassistant.setup] Setup of domain update took 0.0 seconds
2024-02-17 15:21:51.425 INFO (MainThread) [homeassistant.components.update] Setting up update.hacs
2024-02-17 15:21:51.425 INFO (MainThread) [custom_components.hacs] Stage changed: setup
2024-02-17 15:21:51.426 INFO (MainThread) [custom_components.hacs] Stage changed: waiting
2024-02-17 15:21:51.426 INFO (MainThread) [custom_components.hacs] Setup complete, waiting for Home Assistant before startup tasks starts
2024-02-17 15:21:51.426 INFO (MainThread) [custom_components.hacs] Stage changed: startup
2024-02-17 15:21:53.775 INFO (MainThread) [custom_components.hacs] <Integration hacs/integration> Registration completed
2024-02-17 15:21:53.776 INFO (MainThread) [custom_components.hacs] Loading removed repositories
2024-02-17 15:21:53.870 INFO (MainThread) [custom_components.hacs] Loading known repositories
2024-02-17 15:21:54.058 INFO (MainThread) [custom_components.hacs] Stage changed: running
2024-02-17 15:23:35.646 INFO (MainThread) [custom_components.hacs] <Integration MislavMandaric/home-assistant-vaillant-vsmart> Running pre installation steps
2024-02-17 15:23:35.646 INFO (MainThread) [custom_components.hacs] <Integration MislavMandaric/home-assistant-vaillant-vsmart> Pre installation steps completed
2024-02-17 15:23:35.646 INFO (MainThread) [custom_components.hacs] <Integration MislavMandaric/home-assistant-vaillant-vsmart> Running installation steps
2024-02-17 15:23:36.864 INFO (MainThread) [custom_components.hacs] <Integration MislavMandaric/home-assistant-vaillant-vsmart> Trying experimental download
2024-02-17 15:23:37.469 INFO (MainThread) [custom_components.hacs] <Integration MislavMandaric/home-assistant-vaillant-vsmart> Content was extracted to /usr/local/@APP_CONFIG/HomeAssistant/custom_components/vaillant_vsmart
2024-02-17 15:23:37.469 INFO (MainThread) [custom_components.hacs] <Integration MislavMandaric/home-assistant-vaillant-vsmart> Installation steps completed
2024-02-17 15:23:37.469 INFO (MainThread) [custom_components.hacs] <Integration MislavMandaric/home-assistant-vaillant-vsmart> Running post installation steps
2024-02-17 15:23:37.469 INFO (MainThread) [custom_components.hacs] Reloading custom_component cache
2024-02-17 15:23:37.470 INFO (SyncWorker_0) [homeassistant.loader] Loaded hacs from custom_components.hacs
2024-02-17 15:23:37.470 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-17 15:23:37.472 INFO (SyncWorker_0) [homeassistant.loader] Loaded vaillant_vsmart from custom_components.vaillant_vsmart
2024-02-17 15:23:37.472 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration vaillant_vsmart which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-17 15:23:37.472 INFO (MainThread) [custom_components.hacs] Custom_component cache reloaded
2024-02-17 15:23:37.472 INFO (MainThread) [custom_components.hacs] <Integration MislavMandaric/home-assistant-vaillant-vsmart> Post installation steps completed
2024-02-17 15:23:37.474 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hacs
2024-02-17 15:23:37.474 INFO (MainThread) [homeassistant.components.update] Setting up update.hacs
2024-02-17 15:23:37.476 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new update.hacs entity: update.vaillant_vsmart_update
2024-02-17 15:23:37.477 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new update.hacs entity: update.hacs_update
PriestyUK
Post by PriestyUK »
outkastm wrote: ↑20 Jul 2023, 08:06
Please can we have the latest version :)
crisisacting
Post by crisisacting »
PriestyUK wrote: ↑20 Nov 2024, 21:47
Please state for which TOS version you require an update for outkastm, as TOS 6 (builds above 6.0.420) are different than previous TOS 4 & 5; TOS 4 apps no longer get updates & you need to be a paid member on TNAScommunity.eu for TOS 5 updates, however TOS 6 releases should be available eventually, going off this post
spleenrun
France
Post by spleenrun »
hello TOS 6 please
thx
e19
Netherlands
Post by e19 »
I’m currently running a TerraMaster NAS (F4-424 Pro) with TOS 6, and I’m trying to set up a virtual machine to run Home Assistant. My goal is to eventually run Home Assistant permanently on the NAS, with support for my Sonoff Zigbee 3.0 USB dongle (based on the Silicon Labs CP210x chipset).
However, I’ve encountered several issues:
1. VirtualBox on TOS 6 does not allow USB passthrough – the USB options are greyed out and I cannot attach the Zigbee dongle to my Home Assistant VM.
2. The required VirtualBox Extension Pack cannot be installed in the VirtualBox environment provided on the NAS.
3. I need USB device support in my VM for Home Assistant to work with Zigbee (either through ZHA or Zigbee2MQTT).
4. There is limited documentation or guidance on how to properly set up USB devices inside VMs on TOS 6.
My questions:
• Is there any alternative VM engine supported on TOS 6 (e.g., KVM or QEMU) that allows USB passthrough?
• Can you provide guidance on enabling USB passthrough in VirtualBox on TOS 6?
• If VirtualBox is not suitable, is it possible to install Docker with full USB access on this NAS model, and run Home Assistant Supervised or Container with Zigbee support?
• Are there any official recommendations from TerraMaster for running USB-based smart home software (like Home Assistant) on TOS 6?
Any help or direction would be greatly appreciated, as this is a key part of my home automation setup.
Best to ask your questions on the correct forum for virtual machine viewforum.php?f=73
This post is for Home Assistant native app
lapinhand
France
Post by lapinhand »
Bonjour,
Je cherche à installer home assistant sur mon TNAS 4-423 sous TOS6
Je n'y arrive pas car il y a la version tos 5 mais pas pour TOS6.
Quelqu'un pent m'aider, svp.
Home Assistent core installation is deprecated and no longer supported. You need to use the docker guideline or virtaul machine method
