[ ZeroTier ] Securely connect any device, anywhere
chema8132
Re: [ ZeroTier ][ 1.10.1.0 ] Securely connect any device, anywhere
Post by chema8132 »
mts33 wrote: ↑16 Aug 2022, 19:42 Please help
I got 500 error
root@TNAS:/# sudo zerotier-cli join xxxxxxxxxxxxxxxx
500 join {}
root@TNAS:/# sudo -i zerotier-cli listnetworks
Welcome to TNAS
200 listnetworks <nwid> <name> <mac> <status> <type> <dev> <ZT assigned ips>
root@TNAS:/#
Hi! Did you manage to resolve the issue? I'm having the same results on a F4-210
mrpivx
Post by mrpivx »
chema8132 wrote: ↑31 Oct 2022, 22:31
I got 500 error
500 join {}
Welcome to TNAS
root@TNAS:/#
I'm in the same boat with F2-210. Seems like when I add the member manually in zt it will connect and show online but will not work and also gives me the 500 error.
Re: [ ZeroTier ] Securely connect any device, anywhere
up to 1.10.2.0
chema8132
Post by chema8132 »
mrpivx wrote: ↑01 Nov 2022, 09:04
I got 500 error
500 join {}
Welcome to TNAS
root@TNAS:/#
Exactly, that's my case with F2-210 too. I've tested again with the latest version "1.10.2", but I get the same result, maybe @outkastm can help us to take this out? :P
I've been thinking on maybe try the docker version, dunno if it's possible to run ZeroTier that way on this device.
rtn
Post by rtn »
The same problem(F2-210). I will add from myself :
sudo zerotier-one -U
ERROR: unable to configure virtual network port: could not open TUN/TAP device: No such file or directory
modprobe tun
failed to find a module named tun
Sorry but i don't have an arm device to test the arm version of this app.
Can be that is a kernel related issue.
chema8132
Post by chema8132 »
Hi!
Yes, it looks like the Tun Tap kernel driver is not present on ARM TOS, making it imposible for ZeroTier yo create the virtual network adapter needed.
I've been messing around It, manually creating the /dev/net/tun file and things like that, but couldn't manage to get it working, neither by the 3rd application nor the docker container :(
MooieBoot
Post by MooieBoot »
Just a note to others:
When using network bonding (combining multiple interfaces) on TNAS systems with more then 1 ethernet port, zerotier will never connect also when you run zerotier in docker it won't connect and stay offline.
juan26felipe
Post by juan26felipe »
Hola, estaba tratando de usar zerotier pero este no funciona. En contacto con soporte me dicen que no funciona porque no tiene el modulo tun, "Dear, tun is module".
Gracias por el apoyo de las apps y si es posible corrección para poder hacer uso
juan26felipe
Aclaratoria al comentario anterior que deje, esto para los dispositivos ARM, en mi caso F2-210
