[ Jellyfin ] The Free Software Media System
Re: [ Jellyfin ][ 10.7.7.0 ] The Free Software Media System
Functionality will not be affected unless the name of your USB drive will change again, for this I don't know.
But the new firmware is a Must considering the FAN issues reported by some users on the previous version.
scout71
Italy
Post by scout71 »
Thank you so much for your support!
Re: [ Jellyfin ][ 10.8.0.0 ] The Free Software Media System
up to 10.8.0.0
scout71
Italy
Post by scout71 »
outkastm wrote: 13 Jun 2022, 06:34 up to 10.8.0.0
Will it also be possible to use it on TOS 5 or is it better to wait to update? I am using it with great satisfaction on my TOS 4
TM promise to release the app packaging environment for TOS5 next week.
By then, the app cannot be installed on TOS5
scout71
Italy
Post by scout71 »
outkastm wrote: 17 Jun 2022, 00:43 TM promise to release the app packaging environment for TOS5 next week.
Great, so I'll wait for your update before installing the new operating system :D
malstoun
Post by malstoun »
Hi! I have F5-221 and couldn't run 10.8.0.0 on my NAS. No error is reporting, just plain "ok" after clicking "Application control -> Start module" and Jellyfin isn't starting. Unfortunately, I couldn't find any logs. I have a TOS version 4.2.39. Installed a newer version of ffmpeg package (4.4.0.0 vs recommended 4.3.2.0) and 1.00.11 ModBase1 package.
Just to mention, I was able to run it by calling /usr/local/Jellyfin/bin/program/jellyfin and everything works great, but the /etc/init.d/Jellyfin script also writes "ok" and jf doesn't start.
Could you help me to debug what the problem could be?
malstoun
Post by malstoun »
Solved it by fixing permissions on directories
For which directories and what kind of permissions you had to change? Normally shouldn't be needed.
malstoun
Post by malstoun »
It's not the problem of bundle. I just reinstalled TOS a few times with different initial users and some of the directories had wrong user/group and permissions because of that.
