You can refer to this post to reinstall the TOS system: viewtopic.php?t=423
When initialization begins, you can press ESC to enter custom installation mode and manually upload the bootloader and the TOS installation package to install the TOS version you want.
ok, just a thing:
several weeks ago the Support told me to follow this post to install a specific (v1140) TOS7 version:
How to Flash a New USB Initboot for TOS on Windows PC? viewtopic.php?t=6433
and they gave me the TOS7 v1140 installation package (.ins file)
Now you suggest me to follow another post for reinstalling the TOS system (viewtopic.php?t=423).
What is the difference?
For me, i would like to install (or downgrade) TOS7 to a specific version that I used and it was working (i.e. v1140) when i update to a new version (i.e. v1169) but there is a malfuncion/problem with this new version.
Thanks in advance
There was never any chance that those temps were real. The NAS is only a few cm from my knee and I'd have heard the fan going flat out and probably have felt the case glowing......
The initial smartctl commands seem to show both the false and the real temps so I hope they make sense to you.
Based on the current SMART data, both hard drives appear to be operating normally. The values 118, 122, and 125 shown in the logs are normalized SMART Attribute 194 values, rather than actual drive temperatures. The current temperatures of `/dev/sda` and `/dev/sdb` are 25°C and 28°C respectively, both within the normal range. We also found no reallocated sectors, pending sectors, offline uncorrectable sectors, or SATA CRC errors, and the SMART health status is reported as PASSED. Therefore, there is currently no evidence of overheating or a hardware health issue with the drives.
The post from technical support is for recreating the boot system — if your current boot system is not the TOS 7 one, you cannot install TOS 7 directly. The post I shared covers the steps for reinstalling the system. These two posts do not conflict, and you can combine them: first create the TOS 7 boot system, then follow the reinstallation procedure. When the initialization process begins, select custom installation mode and upload the 7.0.1140 installation package.
The system configuration does not include Rsync task configurations. Regarding the issue you mentioned, please check whether the current storage pool and volumes are in a normal state. You can also enter dmesg in the terminal to check whether there are any file system errors. viewtopic.php?t=2575
Dmesg doesn't show any file system errors.
When rsync "crashes" i see the jobs disappearing, the data is being sent to the other side so the jobs keeps on running.
Also i see active rsync process(es). All data is copied and the job ends with error message in notifications stating to view the log.
That log cannot be opened because the job doesnt exist.
BUT: when i create new jobs without RunNow checked they don't disappear and start/end successfully on the planned time.
Also after a reboot the jobs are still there.
-> So creating AND running it seems to be the prob?
F5-221 - TOS7.0.1341 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB F2-221 - TOS7.0.1341 - 2x3TB JBOD - 1x4TB Single USB
Hello TerraMaster Team,
Note: This report is compiled with the help of an AI Assistant to properly translate system diagnostic logs from Russian into English.
I have manually updated my TerraMaster F6-424 Max to the latest release TOS 7.0.1188. During my testing of the virtualization features, I encountered a critical issue: virtual machines completely freeze and lock up under disk I/O load.
System Specs:
• NAS Model: F6-424 Max
• OS Version: TOS 7.0.1188 [1]
• CPU: Intel Core i5-1235U
• RAM: 64 GB DDR5 (Micron)
• BIOS Version:** TM-v1.0.18_T726 (2024/09/20)
• Storage Configuration: Single SATA HDD running TOS, Docker, and VMs combined.
Investigation & The Bug:
To completely isolate any hardware or power management issues, I have manually configured the BIOS: Intel C-States limits are locked to C0/C1, Aggressive LPM Support for SATA is Disabled, and RAM Power Down Mode is Disabled. CPU temperatures stay perfectly fine at +46°C. The hardware itself is 100% stable.
The dmesg kernel trace reveals that the problem is a core architectural software bug in the TOS 7 storage subsystem. Regardless of the disk controller layout selected via the web interface (SATA or VirtIO), the hypervisor back-end wraps virtual disks into the SCST / LIO-ORG / TCM_Loopback iSCSI loop system. Under disk I/O pressure, this emulation stack fails to synchronize its cache, drops the mapping, and triggers a guest Kernel Panic.
Captured dmesg Logs (TOS 7.0.1188):
Here is the log snapshot taken right after the Windows VM froze on the 7.0.1188 build:
[13458.138341] dev[0000000071431d88]: Backstore name 'naa.5157e6a306e662cc' is too long for INQUIRY_MODEL...
[13458.330217] scsi host34: TCM_Loopback
[13458.330686]: scst: Attached to scsi34, channel 0, id 1, lun 0, type 0
[13458.330748] sd 34:0:1:0: [sdc] 20971520 512-byte logical blocks: (10.7 GB/10.0 GiB)
[13678.579251]: scst: Detached from scsi33, channel 0, id 1, lun 0, type 0
[13678.617313] sd 33:0:1:0: [sdb] Synchronizing SCSI cache
[13678.865301]: scst: Detached from scsi34, channel 0, id 1, lun 0, type 0
[13678.910343] sd 34:0:1:0: [sdc] Synchronizing SCSI cache
[13699.327676] x86/split lock detection: #AC: CPU 3/KVM/213612 took a split_lock trap at address: 0xfffff80034c48
Request for the Developers:
The TCM_Loopback driver module drops the device mapping throwing a Detached event while executing Synchronizing SCSI cache.
Please request the virtualization/storage engineering team to look into this thread. The backend of the VMs app should stop wrapping standard local virtual storage drives (.qcow2 / .raw images) into a problematic iSCSI target/loopback architecture when a single drive setup is detected, or fix the cache synchronization pipeline within the modified scst kernel module.
Thank you!
Yes, I could see that for myself but does it get us any closer to finding why the normalised temperatures are reported as if they were the real one in the debug syslog?
F2-425 Plus, 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.0.<latest>
F4-SSD, 16GB RAM, 4 x 4TB WD SN700 Btrfs TRAID, TOS 7.0.<latest>
@snapsh0t:
The fact that someone has chosen to log a "Normalised Value" and then call it Celcius is suspicious of itself
Or maybe it's just a bad attempt at calculating Fahrenheit.
TOS 7 File Manager – Copy/Move destination folder list is not sorted alphabetically
In File Manager, select a file → Copy To/Move To. In the destination-folder selection dialog, folders are not displayed in alphabetical order. Newly created folders appear at the bottom of the list rather than in their alphabetical position. The normal File Manager folder view can be sorted by name, but the Copy/Move destination selector appears to use a different ordering.
Expected: folders displayed alphabetically by name (A–Z).
Actual: folders appear to be displayed in directory/creation order, with recently created folders near the bottom.
We need to further analyze this in combination with the debug logs. Please enable debug mode, and when the issue occurs again and the device restarts, download the debug logs and send them to our technical support email [support(at)terra-master.com].
The debug logs consist of three files: kern.log, syslog, and atop_log. When downloading, please check whether they are being blocked by your browser.
