TOS 7.0.0746 Official Release (X86) is Now Available
snapsh0t
Re: TOS 7.0.0746 Official Release (X86) is Now Available
Post by snapsh0t »
Update from 7.0.706 to 7.0.0746 seemed okay until I tried to update the installed apps. Web Server insisted on installing PHP 7.4 then the installation of both seemed to hang with 'wait' (or 'waiting'?) displayed. Eventually I got bored and clicked on the X when they both admitted they'd been correctly installed. Why on earth have you reverted to the long retired and unsafe PHP 7.4 instead of updating PHP8.0 to the current 8.4?
F2-425 Plus, 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.0.<latest>
F4-SSD, 16GB RAM, 4 x 4TB WD SN700 Btrfs TRAID, TOS 7.0.<latest>
snapsh0t wrote: ↑24 Jun 2026, 01:14
Reverting to PHP7.4 was mentioned previously as a "fix" for other apps (like VirtualBox) breaking under Tos7Beta.
Vanekjin
Post by Vanekjin »
Centralized backupIt crashed and can't see the machine. When I try to download the client from it, it gives an error. {"is_login":true,"code":false,"msg":"invalid api socket","data":false,"time":0,"code_num":99,"code_msg":"invalid api socket"}
просто писец.
snapsh0t
Post by snapsh0t »
Gremlin wrote: ↑24 Jun 2026, 01:38
Oh dear. It's really not ready but their hand was forced by the release of the two new models.
Nitrokalel
Mexico
Post by Nitrokalel »
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod) update ok
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, beta) update ok
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, beta) update ok
F2-423 (2x18TB, TRaid, 32GB, beta) update ok
F2-221 (6TB+10TB, TRaid, 10GB, beta) update ok
D1 SSD (2TB, prod) is recognized
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod)
F2-423 (2x18TB, TRaid, 32GB, prod)
F2-221 (6TB+10TB, TRaid, 10GB, prod)
D1 SSD (2TB, prod)
snapsh0t
Post by snapsh0t »
joka388 wrote: ↑23 Jun 2026, 21:52 Even in the final version, the hard drive sleep function doesn't work for me.
Same here.
greentower
Post by greentower »
F4-424 Pro: update ok, but filemanager not starts -> fix in terminal: #"systemctl enable filemanage.service"
F4-425 Plus: update ok
F5-422: update ok
F4-423: update ok
JSCFORCE
Post by JSCFORCE »
same for me, for the last 2 versions before this one as well.
F4-425 Plus with TOS 7 with 32GB RAM
2 X 2TB (SSD) RAID 1 / EXT4 (OS/APPS)
4 x 28TB RAID 10 / BTRFS (MEDIA)
1 X 2TB (SSD) Hyper Cache
rcruzleroux
Chile
Post by rcruzleroux »
Excelente... muchas gracias... solucionado el problema de los discos. Hasta el momento funcionando sin problemas.
_________________________________
From Chile...
F5-221
