TOS 6.0.530 Official Version Released
Re: TOS 6.0.530 Official Version Released
DimensionAll wrote: ↑13 Sep 2025, 13:56
"Never give up, Never surrender!"
The link you posted is PAGE 1 of THIS thread that you posted under ....
AiK
Belarus
Post by AiK »
Hello. I successfully updated my T12-450 for 5.1.145-00012, and I want to continue the update process to TOS6.
My current system is TOS 5.1.145, BIOS/initBoot 5.13
I have 12 HDD disks configured as RAID10 in one storage pool. This pool has 6 volumes. These volumes work as SMB shares.
Image Image
Unfortunately, I can't do a backup (it's too big). I read the precautions, but I have some questions:
1. Will my information be preserved across all 6 volumes?
2. I'll lose my configuration. Does this include created volumes and created shared folders?
3. What about system settings like NTP client, network ports, etc.?
4. Maybe I miss something. I will be glad for your help.
Thanks!
Hello, under normal circumstances, your data will not be lost after the upgrade, including your storage pools, volumes, and shared folders. Some system settings may need to be reconfigured.
akaserge
Post by akaserge »
Successfully updated F2-221 from 5.1.145-00320 to 6.0.530-00148 (BIOS version MAPL0304V22). Is it worth to update to the latest version of TOS6?
Model F2-221 TOS Version 6.0.794
The latest system has fixed some issues that existed previously. You can upgrade to the latest system version.
dleonmag
Mexico
Post by dleonmag »
Hola a todos. En las indicaciones de precaución, dice: "TOS 6.0.530 incorpora un sistema de archivos raíz completamente nuevo, logrando compatibilidad total con el sistema raíz de Ubuntu 22.04. Sin embargo, ten en cuenta que todas las configuraciones originales del sistema se borrarán tras la actualización. Si necesitas conservar tus configuraciones originales, ¡no continúes con esta actualización!"
Esto es, que si actualizo de TOS 5 a TOS 6, ¿se perderá el orden en el que tengo mis carpetas de archivos y sus contenidos? ¿O qué es configuración original? Gracias por las atenciones.
dleonmag wrote: ↑19 Dec 2025, 02:38 Hola a todos. En las indicaciones de precaución, dice: "TOS 6.0.530 incorpora un sistema de archivos raíz completamente nuevo, logrando compatibilidad total con el sistema raíz de Ubuntu 22.04. Sin embargo, ten en cuenta que todas las configuraciones originales del sistema se borrarán tras la actualización. Si necesitas conservar tus configuraciones originales, ¡no continúes con esta actualización!"
Hola, aquí "configuración original" se refiere a algunas configuraciones relacionadas con el sistema. Los datos que guardas en las carpetas no se verán afectados, incluyendo el orden de las carpetas y su contenido.
Hello, the 'original configuration' here refers to some configurations related to the system. The data you saved in the folder will not be affected. This includes the order of the folders and the content within them.
H4nZ83
Indonesia
Post by H4nZ83 »
hello, are tos update from 5.1.145 to 6.0.530 are the data stored on TRAID will be missing ?
IrisLi
Post by IrisLi »
H4nZ83 wrote: ↑11 Feb 2026, 15:33
We noticed that you have also posted the same question in another section. Please be informed that it has already been replied to there. Kindly check for the response.
Dennis_H
Post by Dennis_H »
I asked a similar question in another thread, but now that I found this one, it seems to be a more natural place...
I have a F2-221 with 10GB and running 4.2.44 with the V17 BIOS.
I would like to update to TOS 6 and it seems possible with this config.
Do I follow the instructions like
1. If your TOS version is below TOS 4.2.44, you need to first update to TOS 4.2.44.
2. If your TOS version is TOS 4.2.44, you cannot upgrade to TOS 5.0 via the update method and must install TOS 5.0.
3. If your TOS version is between TOS 5.0.93 and TOS 5.0.176, you need to first update to TOS 5.0.176.
4. If your TOS version is TOS 5.0.176, you need to update to TOS 5.1.24.
5. If your TOS version is between TOS 5.1.24 and TOS 5.1.145, you need to first update to TOS 5.1.145.
6. If your TOS version is between TOS 5.1.145 and TOS 6.0.229, you need to first update to TOS 6.0.530.
Will I lose data since I should be on the 2GB system now? Does it update it to 8GB and still work, or will I lose data? If I'm going to lose data, do I just flash a new initdisk for TOS6 and start fresh and have to re-init my drives and copy info back from external USB?
