[ Jellyfin ] The Free Software Media System
Re: [ Jellyfin ] The Free Software Media System
Hey, I'm using TOS 5.1 and when I open Jellyfin it says there's a new update to Jellyfin 10.11.0.
Will this update be available soon? Thanks for all your efforts on this outkastm!
- Cookie2979
Hi all,
I recently updated (or tried to) my Jellyfin app from 10.10.7 to 10.11.4 as per the pop in the app itself, however now Jellyfin won't run at all and when I start the module, it stops itself. I have a F2-424 running TOS 5.1.145 and have tried removing all dependency apps (ModBase1, ffmpeg, ffmpeg51) and reinstalled all of them in order and even tried going back to the old 10.10.7 package and I still can't get the app to run. I currently have 10.10.7 installed and the below are the logs I get when I restart and force start the module:
13/01/26 17:00:13 Will use /Volume1 to store config files
13/01/26 17:00:13 The main volume is /Volume1
13/01/26 17:00:13 Config folder exist at /usr/local/@APP_CONFIG/Jellyfin
MODCONFIGPATHHOME=/home/Cookie2979/MOD_CONFIG/Jellyfin
MODCONFIGPATH=/usr/local/@APP_CONFIG/Jellyfin
MAIN_VOLUME=/Volume1
HOME_VOLUME=/Volume1
13/01/26 17:00:16 Will run as user: jellyfin and group: media
SUCCESS!
[17:00:17] [INF] [1] Main: Jellyfin version: 10.10.7
[17:00:17] [INF] [1] Main: Environment Variables: ["[JELLYFIN_LOG_DIR, /usr/local/@APP_CONFIG/Jellyfin/log]"]
[17:00:17] [INF] [1] Main: Arguments: ["/Volume3/@apps/Jellyfin/bin/program/jellyfin.dll", "-d", "/usr/local/@APP_CONFIG/Jellyfin/data", "-C", "/usr/local/@APP_CONFIG/Jellyfin/cache", "-c", "/usr/local/@APP_CONFIG/Jellyfin/config", "-l", "/usr/local/@APP_CONFIG/Jellyfin/log", "--ffmpeg", "/usr/local/ffmpeg51/sys/bin/ffmpeg", "--nonetchange", "--service"]
[17:00:17] [INF] [1] Main: Operating system: Linux 5.15.59 #246 SMP Tue Sep 5 11:49:03 CST 2023
[17:00:17] [INF] [1] Main: Architecture: X64
[17:00:17] [INF] [1] Main: 64-Bit Process: True
[17:00:17] [INF] [1] Main: User Interactive: True
[17:00:17] [INF] [1] Main: Processor count: 4
[17:00:17] [INF] [1] Main: Program data path: /usr/local/@APP_CONFIG/Jellyfin/data
[17:00:17] [INF] [1] Main: Log directory path: /usr/local/@APP_CONFIG/Jellyfin/log
[17:00:17] [INF] [1] Main: Config directory path: /usr/local/@APP_CONFIG/Jellyfin/config
[17:00:17] [INF] [1] Main: Cache path: /usr/local/@APP_CONFIG/Jellyfin/cache
[17:00:17] [INF] [1] Main: Temp directory path: /tmp/jellyfin
[17:00:17] [INF] [1] Main: Web resources path: /Volume3/@apps/Jellyfin/bin/program/jellyfin-web
[17:00:17] [INF] [1] Main: Application directory: /Volume3/@apps/Jellyfin/bin/program/
[17:00:17] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: /usr/local/@APP_CONFIG/Jellyfin/cache
[17:00:17] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
[17:00:17] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Skipping disabled plugin 1.10.10.25 of Intro Skipper
[17:00:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN subnets: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
[17:00:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions: []
[17:00:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Used LAN subnets: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
[17:00:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Filtered interface addresses: ["127.0.0.1", "192.168.0.75", "100.86.147.16"]
[17:00:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Bind Addresses ["0.0.0.0"]
[17:00:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Remote IP filter is Allowlist
[17:00:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Filtered subnets: []
[17:00:23] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: TMDb 10.10.7.0
[17:00:23] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: Studio Images 10.10.7.0
[17:00:23] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: OMDb 10.10.7.0
[17:00:23] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: MusicBrainz 10.10.7.0
[17:00:23] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: AudioDB 10.10.7.0
[17:00:23] [INF] [1] Jellyfin.Server.Migrations.MigrationRunner: Applying migration 'MigrateActivityLogDatabase'
[17:00:23] [WRN] [1] Jellyfin.Server.Migrations.Routines.MigrateActivityLogDb: Migrating the activity database may take a while, do not stop Jellyfin.
[17:00:23] [ERR] [1] Jellyfin.Server.Migrations.MigrationRunner: Could not apply migration 'MigrateActivityLogDatabase'
Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 1: 'no such table: ActivityLog'.
at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)
at Microsoft.Data.Sqlite.SqliteCommand.PrepareAndEnumerateStatements()+MoveNext()
at Microsoft.Data.Sqlite.SqliteCommand.GetStatements()+MoveNext()
at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()
at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)
at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader()
at Emby.Server.Implementations.Data.SqliteExtensions.Query(SqliteConnection sqliteConnection, String commandText)+MoveNext()
at Jellyfin.Server.Migrations.Routines.MigrateActivityLogDb.Perform()
at Jellyfin.Server.Migrations.MigrationRunner.PerformMigrations(IMigrationRoutine[] migrations, MigrationOptions migrationOptions, Action`1 saveConfiguration, ILogger logger)
[17:00:23] [FTL] [1] Main: Error while starting server
at Jellyfin.Server.Migrations.MigrationRunner.Run(CoreAppHost host, ILoggerFactory loggerFactory)
at Jellyfin.Server.Program.StartServer(IServerApplicationPaths appPaths, StartupOptions options, IConfiguration startupConfig)
[17:00:23] [INF] [1] Main: Running query planner optimizations in the database... This might take a while
[17:00:23] [INF] [1] Emby.Server.Implementations.ApplicationHost: Disposing CoreAppHost
[17:00:23] [INF] [1] Emby.Server.Implementations.ApplicationHost: Disposing MusicBrainzArtistProvider
[17:00:23] [INF] [1] Emby.Server.Implementations.ApplicationHost: Disposing MusicBrainzAlbumProvider
[17:00:23] [INF] [1] Emby.Server.Implementations.ApplicationHost: Disposing PluginManager
Can anyone please help?
SUCCESS!
- ChairmanMao
You are missing the table "ActivityLog". Try https://github.com/jellyfin/jellyfin/issues/15158 and https://github.com/jellyfin/jellyfin/issues/15027.Cookie2979 wrote: ↑13 Jan 2026, 15:02 Hi all,
SUCCESS!
Updating Jellyfin from 10.10.7 to the latest version cause my so many issues with the database migration. I ended up starting from scratch again.
F4-423, TOS 6.0.555
Hi everyone. Could you please help me? I have an F-423 and the app version from the store is 10.11.10. I see on GitHub that the app is updated periodically. When will we have an update? I'm really looking forward to it.
The new version will be released on the app store after passing internal testing, and then pushed to all users.
TOS6 & TOS7 updated to 10.11.8.0 for those who are still using the community version.
- nomadfromx
I have the latest version installed from the App Library. Jellyfin itself shows the current version as 10.11.0. Is there any way I can switch from my current version to the community version without losing my configured library?
I'm in the same situation. I have put too much time into the current config, but looks like it is VERY infrequently updated. Tried installing the community version, but that is installed to another location and couldn't see how to move the config over. Maybe now that TOS 7 is out TM can work on updating the store version to the latest.nomadfromx wrote: ↑06 Jul 2026, 16:01 I have the latest version installed from the App Library. Jellyfin itself shows the current version as 10.11.0. Is there any way I can switch from my current version to the community version without losing my configured library?
- Alistaircg
Does anyone know how to get Jellyfin version 12 without installing docker ?
- crisisacting
- Silver Member
As long as your TNAS is running TOS 6.×/7.× (which are Ubuntu-adjacent/based), then you can either:Alistaircg wrote: ↑10 Sep 2026, 23:15 Does anyone know how to get Jellyfin version 12 without installing docker ?
- install it via SSH: https://jellyfin.org/docs/general/insta ... erivatives
OR - use the version that's available on the App Center within TOS 6.×/7.×.
