TOS 6.0.770 (X86) is Released for Update
FredMutter
France
Re: TOS 6.0.770 (X86) is Released for Update
Post by FredMutter »
TMeric wrote: ↑06 Aug 2025, 21:06
If remote access is still unavailable after re-enabling TNAS.online on your NAS, please contact our official Live Chat. We’ll arrange an engineer to assist you remotely. To help our support team quickly understand the issue, include a link to this post.
The problem was solved.
I think the solution was to reset the value of the port 443
He entered 444 and then entered 443 again
I think the main problem was that this file was empty:
cat /etc/tos/config/routine.json
instead of having {"device_name":"TNAS","model_number":"F2-424","ip":"192....
TMeric
Post by TMeric »
FredMutter wrote: ↑07 Aug 2025, 15:36
Fred, thank you for your assistance. The engineer just informed me that the issue has been resolved and the root cause has been identified. The problem occurred because you had used TOS6.0.750 and modified the default https port (5443) before upgrading to TOS6.0.750. This caused remote access to be unavailable after upgrading to versions 750 and 770. The solution is to modify the https port once, which will allow TNAS.online to re-listen to the configuration file.
This issue will only occur if the following conditions are met:
1.The device was upgraded to TOS6.0.750;
2.The default https port (5443) was modified before upgrading to TOS6.0.750;
3.The https port has not been modified since upgrading to TOS6.0.750.
If other users have not used TOS6.0.750 or have not modified the https port, they will not encounter this issue. If any user who has used TOS6.0.750 faces this problem, they can try modifying the https port themselves. You can refer to this link for further guidance: viewtopic.php?t=8715.
thierrys73
France
Post by thierrys73 »
Bravo et Merci fred tout est ok
Tnas T6-423
Tnas F2-221
Joesh
Indonesia
Post by Joesh »
Successful update without any problems
Arendatr
Post by Arendatr »
Not worked Docker Manager
seb
France
Post by seb »
Hello, all seems good on my side after upgrading my F2-423. No issues noticed.
Claus
Germany
Post by Claus »
Hallo,
bei eingerichteten Hypercache laufen die Festplatten nach Neustart eine Ewigkeit. Rad5 Prozess !!!
Ohne aktivierten Hypercache ist nach Neustart alles ruhig.
samius
Post by samius »
After the update from 694 to 770, shortcuts for third-party applications are not displayed on the desktop.
F4-424 MAX TOS 7
rfbjr
Post by rfbjr »
Was away, just installed on both F2/F4-223. The issue I had with Hyper Cache is gone. The reboot as part of the update process was fine. Then another reboot of the F4 did not trigger hours of disk activity. I did not have to delete/re-create the Hyper Cache after the update. I'll start checking other aspects later.
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
sianderson
Post by sianderson »
deleting from the recycle bin over a network share doesn't seem to reclaim the disk space (although files disappear from #recycle folder)
however it does seem to reclaim it when using the "empty recycle bin" option from the file manager within TOS
anyone else experiencing this now trying to figure out how to reclaim the space?
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
