[ Jellyfin ] The Free Software Media System
Re: [ Jellyfin ] The Free Software Media System
you must install 10.10.3.3 and reboot your NAS.
Post the content of the start_log file, remove any sensitive information if needed
- robertosandoval
I've followed the directions for installing the new version 10.10.3.3 and rebooted your NAS.
It's barely working; after 2-3 seconds of streaming, the video freezes. If I play 4K videos using the web app, some of them can play with transcoding, but others freeze after 2-3 seconds. If I play the same 4K video on the Jellyfin Mobile App, transcoded to 1080p, it only plays for 2-3 seconds before freezing and showing the background image.
The output streaming display size is 1080p.
- robertosandoval
00:02.0 VGA compatible controller [0300]: Intel Corporation JasperLake [UHD Graphics] [8086:4e55] (rev 01)
[ 136.500506] Setting dangerous option enable_guc - tainting kernel
[ 136.527610] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/icl_dmc_ver1_09.bin (v1.9)
[ 136.569195] i915 0000:00:02.0: [drm] GuC firmware i915/ehl_guc_70.1.1.bin version 70.1.1
[ 136.569209] i915 0000:00:02.0: [drm] HuC firmware i915/ehl_huc_9.0.0.bin version 9.0.0
[ 136.583800] i915 0000:00:02.0: [drm] HuC authenticated
[ 136.584151] i915 0000:00:02.0: [drm] GuC submission enabled
[ 136.584156] i915 0000:00:02.0: [drm] GuC SLPC disabled
NAS model is F2-423
huc loaded
Will run as user: jellyfin and group:
SUCCESS!
[21:59:11] [ERR] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.KeyRingProvider: An error occurred while reading the key ring.
System.UnauthorizedAccessException: Access to the path '/home/jellyfin/.aspnet/DataProtection-Keys/key-87be101f-a782-49be-be0d-55e3a464a8b8.xml' is denied.
---> System.IO.IOException: Permission denied
--- End of inner exception stack trace ---
at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirError)
at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode, Boolean failForSymlink, Boolean& wasSymlink, Func`4 createOpenException)
at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, UnixFileMode openPermissions, Int64& fileLength, UnixFileMode& filePermissions, Boolean failForSymlink, Boolean& wasSymlink, Func`4 createOpenException)
at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize, Nullable`1 unixCreateMode)
at System.IO.File.OpenRead(String path)
at Microsoft.AspNetCore.DataProtection.Repositories.FileSystemXmlRepository.ReadElementFromFile(String fullPath)
at Microsoft.AspNetCore.DataProtection.Repositories.FileSystemXmlRepository.GetAllElementsCore()+MoveNext()
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
at Microsoft.AspNetCore.DataProtection.Repositories.FileSystemXmlRepository.GetAllElements()
at Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager.GetAllKeys()
at Microsoft.AspNetCore.DataProtection.KeyManagement.KeyRingProvider.CreateCacheableKeyRingCore(DateTimeOffset now, IKey keyJustAdded)
at Microsoft.AspNetCore.DataProtection.KeyManagement.KeyRingProvider.GetCurrentKeyRingCore(DateTime utcNow, Boolean forceRefresh)
[21:59:11] [WRN] [1] Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware: The WebRootPath was not found: /wwwroot. Static files may be unavailable.
[21:59:12] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version 7.0.2
[21:59:12] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available decoders: ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "ac4", "dca", "flac", "mp3", "truehd"]
[21:59:12] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available encoders: ["libsvtav1", "av1_nvenc", "av1_qsv", "av1_amf", "av1_vaapi", "libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mjpeg_qsv", "mjpeg_vaapi", "aac", "libfdk_aac", "ac3", "alac", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
[21:59:12] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["bwdif_cuda", "deinterlace_qsv", "deinterlace_vaapi", "flip_vulkan", "hwupload_cuda", "hwupload_vaapi", "libplacebo", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_vulkan", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "scale_vulkan", "tonemapx", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "transpose_cuda", "transpose_opencl", "transpose_vaapi", "transpose_vulkan", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
[21:59:12] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
[21:59:15] [INF] [10] Emby.Server.Implementations.ScheduledTasks.TaskManager: Limpiar directorio de transcodificado Completed after 0 minute(s) and 0 seconds
[21:59:15] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: Limpieza de colecciones y listas de reproducción Completed after 0 minute(s) and 0 seconds
[21:59:17] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: VAAPI device /dev/dri/renderD128 is Intel GPU (iHD)
[21:59:17] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: /Volume1/@apps/Jellyfin/ffmpeg/ffmpeg
[21:59:17] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: c9a90befb6704da9981c4ffb4f7dbe18
[21:59:17] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
[21:59:17] [INF] [1] Main: Startup complete 0:00:10.5701872
[21:59:17] [ERR] [16] Emby.Server.Implementations.Updates.InstallationManager: An error occurred while accessing the plugin manifest: https://repo.codyrobibero.dev/manifest.json
System.Net.Http.HttpRequestException: Name or service not known (repo.codyrobibero.dev:443)
---> System.Net.Sockets.SocketException (0xFFFDFFFF): Name or service not known
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token)
at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|285_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken)
at Jellyfin.Networking.HappyEyeballs.HttpClientExtension.AttemptConnection(AddressFamily addressFamily, SocketsHttpConnectionContext context, CancellationToken cancellationToken)
at Jellyfin.Networking.HappyEyeballs.HttpClientExtension.OnConnect(SocketsHttpConnectionContext context, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.<SendCoreAsync>g__Core|5_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.<SendCoreAsync>g__Core|5_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
at System.Net.Http.Json.HttpClientJsonExtensions.<FromJsonAsyncCore>g__Core|12_0[TValue,TJsonOptions](HttpClient client, Task`1 responseTask, Boolean usingResponseHeadersRead, CancellationTokenSource linkedCTS, Func`4 deserializeMethod, TJsonOptions jsonOptions, CancellationToken cancellationToken)
at Emby.Server.Implementations.Updates.InstallationManager.GetPackages(String manifestName, String manifest, Boolean filterIncompatible, CancellationToken cancellationToken)
NAS model is F2-423
huc loaded
SUCCESS!
Hello. I have repeatedly encountered some error that causes Jellyfin to be disabled in F2-423.
Here is the log excerpt:
[02:29:21] [INF] [22] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:30:52] [INF] [30] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:30:52] [INF] [28] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:32:23] [INF] [31] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:32:23] [INF] [27] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:33:54] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:33:54] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:35:25] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:35:25] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:36:56] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:36:56] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:38:27] [INF] [22] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:38:27] [INF] [27] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:39:58] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:39:58] [INF] [30] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:41:29] [INF] [23] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:41:29] [INF] [23] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:43:00] [INF] [24] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:43:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:44:31] [INF] [24] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
[02:44:31] [INF] [24] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Deleted Notifier Completed after 0 minute(s) and 0 seconds
[02:45:57] [FTL] [27] Main: Unhandled Exception
System.ArgumentException: An invalid IP address was specified. (Parameter 'address')
at System.Net.NetworkInformation.LinuxNetworkInterface.GetLinuxNetworkInterfaces()
at System.Net.NetworkInformation.NetworkInterfacePal.GetIsNetworkAvailable()
at System.Net.NetworkInformation.NetworkChange.OnAvailabilityTimerFired(Object state)
at System.Threading.TimerQueueTimer.Fire(Boolean isThreadPool)
at System.Threading.TimerQueue.FireNextTimers()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading.PortableThreadPool.WorkerThread.WorkerThreadStart()
Unhandled exception. System.ArgumentException: An invalid IP address was specified. (Parameter 'address')
- FredMutter
this is the error
this is the error
Model: F2-424 with TOS 7.0.0777 Bios V08
Are you using some docker containers that are started/stopped constantly?
i'm using Jellyfin TOS5 10.9.4.0 aarch64.tpk.
I configured dir /Volume1/Film as share with my films but the scan doesn't found anything. (My files .mkv are under /Volume1/Film/Films)
Please help
Please help
My question was if you are using some docker containers (not Jellyfin) that constantly start / close network interfaces. You can try the latest Jellyfin 10.3. 5.0. May include also a fix for this
I personally doesn't encounter such error.
