I have TOS 6.0.436 and I didn't find any solution in this forum about email notification problem.
Did someone solved the problem?
I had also configured Custom SMTP Server with no positive result.
I'm available to give necessary information/logs/connections to TM Team to solve the problem.
Thanks!
I fixed mine. Search for "TLS/SSL" on this forum. My mail service provider provides port 465 for TLS you may have to check with your provider's configuration options. If you use Gmail - tough! - Gmail's default setup blocks machine generated emails. You have to make special arrangements which are detailed somewhere. (I only have backup accounts on Gmail)
The error is really consistent. I have 3 disks. Whenever I copy to disk 1, I hit bad transfer speed and 100% CPU rate. Copying to any other disk raises the CPU abnormally, but not to 100%, (maybe 80).TMzethar wrote: ↑19 Aug 2024, 14:40Thank you for the additional information. You mentioned at least two other people experiencing issues consistent with what you presented, can you point us to any of the relevant threads?
There may be an unknown reason for the brief rise in CPU usage. We recommend that you continue communicating with your tech support email and schedule a remote troubleshooting appointment.
Also, docker and Plex tend to hit 100 usage really easily, just trying to create a stack, where it needs to download the image loads the system so much that it says it failed but minutes after the container is there... MINUTES
Any info you need, ping me.
How would you change the OS?golgoth wrote: ↑18 Aug 2024, 22:47 Really, just take your terramaster NAS (wonderful piece of hardware) and put another OS in it.
I had some (big) issues with TOS 6, no solutions found at all and not even identified the cause. Now i'm doing a backup of my data at the speed of 5-10 MB/sec because of high CPU load: it will take weeks, but at the end i will be able to put a working OS inside my F4-424 PRO.
I recommend you to try to copy to other place than the 1st disk, and use cpulimit to avoid the issue. I backup using rsync and cpulimit to 70% and managed to get good transmission speed
Regarding Portainer, at least when you want to deply new stacks, access it directly by typing in your browser http://yournasip:19000 and not via TOS. You should not get anymore the error during stack deplymentspamdz12o wrote: ↑22 Aug 2024, 12:33The error is really consistent. I have 3 disks. Whenever I copy to disk 1, I hit bad transfer speed and 100% CPU rate. Copying to any other disk raises the CPU abnormally, but not to 100%, (maybe 80).TMzethar wrote: ↑19 Aug 2024, 14:40Thank you for the additional information. You mentioned at least two other people experiencing issues consistent with what you presented, can you point us to any of the relevant threads?
It depends on the OS you wanna use, in my case i had to switch the internal USB with another one. Anyway i've been able to make a backup of my data through SMB and installed unraid: now everything is butter smooth.spamdz12o wrote: ↑22 Aug 2024, 13:16How would you change the OS?golgoth wrote: ↑18 Aug 2024, 22:47 Really, just take your terramaster NAS (wonderful piece of hardware) and put another OS in it.
Hi,golgoth wrote: ↑22 Aug 2024, 17:51It depends on the OS you wanna use, in my case i had to switch the internal USB with another one. Anyway i've been able to make a backup of my data through SMB and installed unraid: now everything is butter smooth.spamdz12o wrote: ↑22 Aug 2024, 13:16How would you change the OS?golgoth wrote: ↑18 Aug 2024, 22:47 Really, just take your terramaster NAS (wonderful piece of hardware) and put another OS in it.
can I ask why you preferred Unraid over Truenas Scale? Too much memory needed from the latter?
TNAS F4-423
RAM 20GB (4GB TM + 16GB Crucial CT16G4SFRA32A)
Proxmox 8.3 - OMV 7.7.3 - Dockers
SSD 1TB Lexar NM610PRO NVMe
HDD 20TB Toshiba MG10ACA20TE
HDD 18TB Toshiba MG09ACA18TE
HDD 8TB Seagate ST8000VN004-2M2101
HDD 3TB Western Digital WD30EXRX-00MMMB0
As it was said in the beginning:
2. This update is only applicable to TOS 5.1.145 or later versions.
I misunderstood the version numbering. I'll find 5.1.145. Why is that version not available as the latest update available for TOS5 through the system control panel?
