Updated F2-424 {Skipped previous version .0485}
No issue within update process. One "test" of note - Installation of Docker Manager: System prompted for 'auto-install' of Docker Engine (laudable and logical). Install proceeded with ease and no problem. However, Docker Engine did not 'enable', so Docker Manager failed when opened with (the obvious) error message. Docker Engine had to be enabled manually.
TOS 7.0.0517 Beta (X86) is Released for Update
Re: TOS 7.0.0517 Beta (X86) is Released for Update
The update went smoothly.
There are some issues in Docker Manager (2.2.004) — stacks/projects created outside of it are marked as errored:
All stacks/projects (except dockhand) was created in Dockhand:
F4-424 Pro
TOS 7 involves a substantial number of feature developments, and a stable version cannot be released at this time. Some optimizations in the beta version have yet to be completed, and the integration of AI capabilities into the TOS 7 system is still in progress. We kindly ask for your continued patience. The official release of TOS 7 will be something exciting to look forward to.
The reason why projects created outside of the Docker Manager are marked as errors is that their YAML configuration files cannot be retrieved. The product team is discussing an appropriate way to display these projects.
Regarding the first issue, if you are referring to the USB device information not being displayed correctly, you can try logging out and logging back in; the page will retrieve the information again.
As for the second issue, during the initialization of the dashboard, the card layout initialization failed, resulting in the loss of associated data for the card display settings, which caused subsequent dashboard visibility settings to be unable to sync preferences properly. This issue has been fixed and will be released in the next version.
- Nitrokalel
la interface de docker esta bellisima y esta excelente, tube que actualizar y despues reiniciar 2 veces para que los ambios asentaran bien pero al momento funciona muy bien.
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, beta) update ok
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, beta) update ok
F2-423 (2x18TB, TRaid, 32GB, beta) update ok
F2-221 (6TB+10TB, TRaid, 10GB, beta) update ok
D1 SSD (2TB, prod) is recognized by the new update
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod)
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod)
F2-423 (2x18TB, TRaid, 32GB, prod)
F2-221 (6TB+10TB, TRaid, 10GB, prod)
D1 SSD (2TB, prod)
D1 SSD (2TB, prod)
This is a known issue. Some services are not ready after update and reboot at this time. You need to wait for a while then refreash the web page. we will resolve it in the future coming versions.
Hello!
I've successfully upgraded my TNAS F4-425 from TOS 6 to 7 (of course going the long way, starting with 7.0.0299, then updating to this latest version 7.0.0517). Everything went smoothly at first.
About 15-20 minutes into 0517, the OS seems to have crashed. I had clicked to update docker and portainer (both were disabled), and left it alone for 5 minutes or so. When I came back to my computer, it said to click anywhere on the screen to log back into TOS (I guess my session timed out). When I clicked, it took me to a basic grey background login screen (with images missing). I entered my login, then pwd, and it would do nothing. I tried on another browser (private tab) and same thing was happening. I noticed there was no HDD activity on the NAS, so I rebooted about 10 minutes later, since nothing was responding. It's now restarted, and there is still no HDD activity, and now no web gui, TNAS does not appear on TNAS PC for Windows. The TNAS still responds to ping though, and it is indeed the correct IP. When trying to SSH, I'm asked my login, but as soon as I enter it, the TNAS closes the network connection.
EDIT: After a third reboot, things are back to normal again.
Hello,CursaYang wrote: ↑15 Apr 2026, 19:22Regarding the first issue, if you are referring to the USB device information not being displayed correctly, you can try logging out and logging back in; the page will retrieve the information again.
Regarding bug 1, I mainly thought that the disk shouldn't be displayed.
EDIT: It's ok, he is now hidden.
