TOS 6.0.783 (X86) is Released for Update
ORION
Re: TOS 6.0.783 (X86) is Released for Update
Post by ORION »
I just updated it, and everything is fine. He didn't ask me to do anything with the volumes
F4-424 Pro :roll:
F2-210 :D
jositodc
Spain
Post by jositodc »
Updated on my F2-221.
So far, all my services are working correctly. The update has been quick and easy, without any issues.
TNAS F2-221 / 6.0.783 8-)
sianderson
Post by sianderson »
all 3 devices, updated successfully, no issues reported (other than it hasnt detected the USB drives) but they may just need turning off and on again for it to detect them, im aware my baracudas are "dodgy" hahaha so cant hold the update to account for this one
EDIT: yep USB detected upon reconnect of the USB so all good
F2-424 TOS 7.0.1140
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Ludovic
France
Post by Ludovic »
Tried the update today and after rebooting can't ping my Nas anymore... So I've just checked in the terminal with hdmi cable and keyboard, checked my IP and oh no IP on interface eth0, so I've set an static IP and problem is solved...
Is anyone else has problem getting address from dhcp Server after tos update?
F4-424 - 8GB - 4*4To HDD - RAID5 - 2*250Gb NVME - RAID1
Ludovic wrote: 25 Sep 2025, 05:43
What was the TOS system version before the update?
Before the update, were you using a static IP or DHCP?
We will attempt to reproduce the issue based on the situation you mentioned.
hawkhunter wrote: 23 Sep 2025, 23:02 T12-423 also updated successfully from -770 to -783.
The T12-423 has 12 Disks ( 6 x 20Tb and 6 x 4TB Seagate) and 5 Disks (16TB) in the D6-320. In version 770 I had 4 system disks (2 of the 20 TB and 2 of the 4 TB). After Deleting one 4 TB System Disk - with the new Tool (since 770) - the System synchronized. Now i have 11 System Disks, all Disks except the one deleted.
How do I get rid of the other 5 (4TB) system disks
Greetings
Strange situation. Under normal circumstances, TOS6 will no longer automatically synchronize or expand the system partition.
It is recommended that you contact the official website's Live Chat window to schedule an engineer to remotely check it for you. (Please mention the URL of this post.)
Nitrokalel wrote: 24 Sep 2025, 01:26 Tengo 2 equipos, F4-424 Pro y el antiguo F2-423 por necesidad tengo que conectarlos por wifi, al actualizar pierden la configuración wifi ambos y me quedo sin manera de reconfigurarlos, tengo que conectar por cable y bolver a meter la contraseña, y dado que los tengo conectados por wi-fi es evidente que me cuenta mucho colocar el cable, tengo que desmontarlos, desconectarlos del lugar donde estan y luego conectarlos de nuevo conectarlos por cable ethernet y reconfigurar la tejeta wifi, es molesto esto, pueden corregirlo¡
We have reproduced the abnormal situation you mentioned. It will be fixed in a future TOS system version. We apologize for the problem you encountered.
Ludovic
France
Post by Ludovic »
TMzethar wrote: 25 Sep 2025, 14:14
I was on tos 6.0.770 if I remember. And before update I was on dhcp
Edit: I can't reactivate dhcp because he didn't get ip. Other client wired or just wireless are getting an IP it's just an issue with tos.
Edit 2: Searched in /var/log/syslog for any revelant information about ipv4 but nothing only regarding the ipv6 that is set to auto in tos, and can't change any settings for eth1. and no ip.. I've also tried with another router and doesn't work too...
hglow1101
Japan
Post by hglow1101 »
After updating, my F6-424MAX stopped responding. I waited 8 hours, but it was still inaccessible.
I had to perform a hard reboot to regain access. After logging in, it showed the update was successful, and everything seems fine so far.
However, every time I reboot, the system starts synchronizing the storage pool again. I’m not sure why this keeps happening.
F6-424MAX - 32GB - 4x8TB 2x16TB HDD - T-RAID - 2x1TB NVME - RAID1 (Read -Write mode cache)
TMlinda
Post by TMlinda »
hglow1101 wrote: 27 Sep 2025, 09:31
You can try the following: powering off the device, reinserting the hard drive, and ensuring it's fully seated before restarting; or switching the hard drive to a different slot before restarting the device.
If you still encounter this issue, please generate and download a system report in TOS > Technical Support > Problem Report, then send it to our technical support email and we will analyze it.
