TOS 6.0.770 (X86) is Released for Update
thierrys73
France
Re: TOS 6.0.770 (X86) is Released for Update
Post by thierrys73 »
RyanYang wrote: 06 Aug 2025, 20:00
FredMutter wrote: 06 Aug 2025, 19:55 Local access and SMB are working fine — I can access my server locally without any issues. I never use remote login myself; I just wanted to let you know that it’s no longer working, as someone else had pointed out.
FredMutter wrote: 06 Aug 2025, 19:49
When accessing via LAN(Local Area Network), the remote access address will automatically switch to the local network address.
You may try checking your remote ID using mobile data.
I noticed that on my Terramaster account my password no longer works.
I'm trying to change my password and so far I can't, I don't receive a password reset email.
Tnas T6-423
Tnas F2-221
FredMutter
France
Post by FredMutter »
RyanYang wrote: 06 Aug 2025, 20:00 You may try checking your remote ID using mobile data.
it says "check if your address and port are correct"
sianderson
Post by sianderson »
F2-424 updated successfully also, only slight "complaint" the timer that counts down from 5 minutes, is there anyway this can actually detect when its done and back up ready to be used?, using an M.2 drive i believe it had actually done the update after 2 minutes but i still left it to count down the final 3 minutes so it refreshed itself back to the login page
F2-424 TOS 7.0.1140
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
TMeric
Post by TMeric »
thierrys73 wrote: 06 Aug 2025, 20:09
Please check your spam folder first; if the email is still missing, let us know your email provider so we can investigate further.
TMeric
Post by TMeric »
FredMutter wrote: 06 Aug 2025, 20:10
If remote access is still unavailable after re-enabling TNAS.online on your NAS, please contact our official Live Chat. We’ll arrange an engineer to assist you remotely. To help our support team quickly understand the issue, include a link to this post.
ORION
Post by ORION »
TNAS-424Pro update went smoothly from 694=>770, no bugs or network disconnections
F4-424 Pro :roll:
F2-210 :D
OttO1916
Netherlands
Post by OttO1916 »
Both my F2-221 and F5-221 upgraded from 6.0.750 to 6.0.770, fast and smooth. Works like a charm, no issues whatsoever. Thanks!
F5-221 - TOS7.0.1140 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1140 - 2x3TB JBOD - 1x4TB Single USB
thierrys73
France
TMeric wrote: 06 Aug 2025, 20:54
ok my email provider is aol.com and the notifications of my T6-423 are ok
for example i receive the email from the update to 6.0.770
Tnas T6-423
Tnas F2-221
jpeckinp
Post by jpeckinp »
Add me to the remote access not working group. I enter my info on the remote access page and I keep getting operation failed.
EDIT: Found my issue. Something in Adguard Home was keeping me from getting in. I disabled a few filters at a time until it worked. I re-enabled one at a time and it didn't block me anymore. So I'm not sure which filter it was.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
FredMutter
France
TMeric wrote: 06 Aug 2025, 21:06
The problem was solved.
I think the solution was to reset the value of the port 443
He entered 444 and then entered 443 again
I think the main problem was that this file was empty:
cat /etc/tos/config/routine.json
instead of having {"device_name":"TNAS","model_number":"F2-424","ip":"192....
