F8 SSD Plus
Patricide
Belgium
Re: F8 SSD Plus
Post by Patricide »
Is there any update on this? Considering to buy an F8 SSD (non-plus) but ASPM is a must-have :).
Re: F8 SSD Plus
The new F8 SSD/F8 SSD Plus BIOS version has adjusted and optimized ASPM.
If you own or have just purchased an F8 SSD/F8 SSD Plus and are encountering this issue, please refer to the guide to update the BIOS version, and then press [Crtl]+[,] or [Crtl]+[Del] to enter the hidden menu to adjust ASPM.
viewtopic.php?t=8961
storageninja
Netherlands
Re: F8 SSD Plus
Post by storageninja »
Could someone post the screenshot of the hidden settings?
Re: F8 SSD Plus
storageninja
Netherlands
Re: F8 SSD Plus
Thank you, is there such for my F4 SSD too?
Re: F8 SSD Plus
storageninja wrote: ↑28 Sep 2025, 19:07
The F4 SSD does not have such a problem.
storageninja
Netherlands
Re: F8 SSD Plus
TMzethar wrote: ↑28 Sep 2025, 19:55
Not the bug with the bios and 3th party OSes. Is ASPM also supported, already, on the F4?
Re: F8 SSD Plus
storageninja wrote: ↑28 Sep 2025, 19:57
Yes. The F4 SSD can use ASPM normally.
storageninja
Netherlands
Re: F8 SSD Plus
TMzethar wrote: ↑28 Sep 2025, 20:23
Thanks for the confirmation.
Sven
Germany
Re: F8 SSD Plus
Post by Sven »
TMzethar wrote: ↑28 Sep 2025, 18:53
"First of all, thank you very much — I really didn’t expect anything to happen anymore.
I followed the instructions completely and successfully, but I can’t find the function in the BIOS that you showed on the F8 SSD Plus, even though I installed all the updates."
Is there maybe another function where this can be unlocked?
CASE: Terramaster F8 SSD PLus
SSD: 8x 2TB NVME Crucial P3
HDD: 2X20TB
IOS: Unraid
Net: 1 Gig Fiber
