TOS 6.0.577 (X86) is Released for Update
Re: TOS 6.0.577 (X86) is Released for Update
it is treated like this: install it by force, not through the "app store"
F4-424 Pro
F2-210
F2-210
Today there was an update of docker manager, everything is fine with the docker hub registry.TMRyan wrote: ↑25 Dec 2024, 08:59Due to the inability of the interface used in the Docker Engine to retrieve image information from the Docker official image list (registry), the registry is currently unable to display the list of images. We are in the process of adapting to a new interface. In the meantime, you can temporarily use the terminal on the TOS desktop to pull images using commands. We will update the application as soon as possible to resolve this issue.
does anyone know what is the cause of the qbittorrent v 4.1.13 Bad Gateway 502 error? for some reason, it opens port 5443 at startup, and the port settings specify two 8999 and 8282 ports, but if you click on them, the web does not work.
F4-424 Pro
F2-210
F2-210
It's a risk you take... I tried it because I had already installed the beta 6.0.229 without any problems. The subsequent betas damaged my F2 221 (NAS that I repaired myself, after Terramaster was unable to help me). If you know that with 6.0.229 your F2 had no problems i think most likely you can update to 6.0.530 directly.skyrocket777 wrote: ↑25 Dec 2024, 02:32Hello. I also have an F2-221, my current TOS is 5.1.67
I wonder if I should install the latest beta version TOS 6.0.530 (and then upgrade it automatically)
Or should I just wait until the Control Panel update comes out from 5.1.67
What you think?
Thank you
Penso stiano aspettando di capire cosa succede con la 6.1.530 prima di sbilanciarsi....scout71 wrote: ↑24 Dec 2024, 23:40Thank you! I always understood that TOS 6.x was not compatible with the 221 series (as they wrote in version 6.530, the only one that can be installed without the beta)... who knows if they will put a version that we can also install with the 221 series, I'm waiting for it with curiosity.
Frustrated Beta Tester!!!
WebDAV didn't work and doesn't work. This is a mockery. There was TOS 5, everything worked, then it was updated to TOS 6 and half of the functionality stopped working. Probably 10 updates have already been released, but the problems are not solved.
It's a disgrace.
It's a disgrace.
After installing the new update (automatic install) on my F4-424 MAX, I couldn't log onto the server admin webpages, using <Server IP>/tos/#/desktop and get 502 Bad Gateway nginx/1.21.0. or via remote server connection or putty. What do I need to do get this this working again? I've rebooted several times but that didn't resolve the issue?
Any update on TOS 6 support for F5-221 models? I dont see it yet available for that model yet?
