TOS 6.0.512 (X86) is Released for Update
Lex
Re: TOS 6.0.512 (X86) is Released for Update
Post by Lex »
If I change some in NFS, in the /etc/exports file add strange new line. start with "" *.
Empty path with global mask. And I cant mount NFS folder. Delete this line fix permission.
F4-423
Ottavio
Italy
Post by Ottavio »
Good morning,
I have an F2-221 with software version 5.1.145, how do I update it to version 6.XXX?
Ottavio wrote: 18 Oct 2024, 16:58 Good morning,
No upgrade method is currently available. Please watch for subsequent announcements.
editsmith
Australia
Post by editsmith »
Terramaster Engineers, can we add a way to monitor file transfers in the file manager. Example - if you add a remote server then xfer files from it to the host server there is no way to monitor that transfer, it's more than a little frustrating as you have no way to tell if it's even completed.
editsmith wrote: 19 Oct 2024, 17:23 Terramaster Engineers, can we add a way to monitor file transfers in the file manager. Example - if you add a remote server then xfer files from it to the host server there is no way to monitor that transfer, it's more than a little frustrating as you have no way to tell if it's even completed.
Yes. What happened to the 'File Task' button from Tos5?
DekkaR
Iceland
Post by DekkaR »
BUG reported:
TOS: 6.0.512-00137
Problems with the TCP/IP stack.
No accessible ports, for example SSH or 3306 (MariaDB).
Solution: Disable/enable the SSH or Telnet service in the graphical interface, and everything works again.
But if the NAS is rebooted or turned off, the same problem again.
The web server (port 8181) of the system always works.
TM F8 SSD: 16GB RAM. 6TB TRAID EXT4:
TOS 6.0.610: Plex Server 1.41.1.9057: qBitTorrent 4.1.13: Bot.Torrent 4.0:
TM F8 SSD Plus: 32GB RAM. 4TB RAID0 EXT4:
TOS 6.0.531: MariaDB 10.3.29: phpMyAdmin 5.1.22:
[ DekkaR ]
Can't say I noticed. Updated to 6.0.519 today and telnet is working fine with no intervention.
DekkaR
Iceland
Post by DekkaR »
Gremlin wrote: 20 Oct 2024, 08:31
On my F8SSD+ I don't get that update. Where can I download it?
[ DekkaR ]
It has not been announced as far as I know but it was 'pushed' to my nas.
jpeckinp
Post by jpeckinp »
Gremlin wrote: 20 Oct 2024, 08:31 Can't say I noticed. Updated to 6.0.519 today and telnet is working fine with no intervention.
.519?? Only see .512 Did it get pulled already?
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
